Old 04-29-2003, 11:02 AM   #1
MP3Van2003
Found a replacement for copilot 2k3 reciever
Its pretty simple, buy a copilot reciever for the ipaq, on ebay for about 40-60 bucks and just add a serial cable or usb adapter to it. It does work with copilot 2k3 I tried it myself. The only hard part is determining what interface your reciever uses, some of the ipaq recievers use serial (rs232) and some use the usb (+data, - data, ground, 5V) Th eidea dawned on me and I picked one up from ebay and it werked. The ipaq copilot is 12 channel and very small.
MP3Van2003 is offline   Reply With Quote
Old 05-01-2003, 02:45 AM   #2
e36mp3
How do you add the serial or usb cable to it?
e36mp3 is offline   Reply With Quote
Old 05-01-2003, 11:19 PM   #3
MP3Van2003
Chop off the end and solder it to the bare wires, note if yours uses the serial version you will have to get power from your ps2 port or some other 5 volt source
as far as what pin goes to where you need to locate the pinout of the ipaq 3600 connector and use that I would post it but i dont hvae that info readily available
