Old 06-11-2003, 05:28 AM   #1
Registered User
aoLhaTer's Avatar
aoLhaTer
getting mappoint to work with earthmate & a cool gps program i found
1) Is there anyway to get the DeLorme Earthmate USB to work with MS MapPoint? Doesnt work because of NMEA compliancy.
The error recieved is:
"The GPS receiver is sending messages, but they are not being recognized as NMEA 2.0-compatible. Make sure the GPS receiver input/output format is set to deliver NMEA 2.0-compatible messages at the correct baud (4800 bps)."
I have SA2003 also but Id like to see what MapPoint with AGPS can do
2) I also found this relatively cool GPS program called GEM located here http://www.schaik.com/gps/gem/gem.html
It uses online map system from Mapquest. Couldnt get it to work with my Earthmate though
aoLhaTer is offline   Reply With Quote
Old 06-11-2003, 06:55 PM   #2
az1324
Wow that GEM program IS pretty cool... for those who don't have a full-featured GPS program. And the aerial photos are sweet.
az1324 is offline   Reply With Quote
Old 06-12-2003, 09:13 AM   #3
Telek
Earthmate is NMEA compatible, AFAIK (I had one, it worked fine with NMEA and S&T and a few other programs that require NMEA)
"The NMEA output allows the Earthmate ™ GPS to be used with other software mapping programs"
Oh, is your Earthmate the old one? Because apparently the new USB one is NMEA compatible
http://www.delorme.com/earthmate/default.asp
Otherwise you might find this page to be of great help
http://www.gpss.co.uk/earthmat.htm
GEM is also supposed to work directly with an earthmate, so I don't know why yours isn't.
Good luck.
IN DEVELOPMENT -- '96 Mustang, lilliput with PII/450 laptop, custom DC-DC power supply, 60GB; Garmin GPS; 802.11g; compact keyboard, small graphical LCDs, OBDII.
Telek is offline   Reply With Quote
