Old 06-26-2003, 12:32 PM   #1
code3response
GPS SOftware CO-Pilot 2003
I read somewhere that the software comes with an actualy GPS receiver in the bundle for somethign like $350. Can I buy JUST the software somewhere? I dont need the GPS receiver - I already ahve one. Any links? Thanks
code3response is offline   Reply With Quote
Old 06-26-2003, 03:55 PM   #2
Typhoon747
No the software is not legaly sold without the reciever.
You can try Ebay, but those auctions get pulled pretty quickly.
Plus I belive that CP2002 and 2003 will not work without the bundled GPS. CP2001 works fine with other GPS's though.
2004 F350 Ext. Cab
System not reinstalled in it yet
Typhoon747 is offline   Reply With Quote
Old 06-26-2003, 06:06 PM   #3
az1324
CP2003 does work with the rand mcnally receiver. I think the only way to get the software without the receiver is to purchase the upgrade.
http://recorderworld.com/20travcopup.html
http://goessex.com/store/rvtravel_software.html
I believe all you need is a registration key.
az1324 is offline   Reply With Quote
Old 06-26-2003, 06:29 PM   #4
code3response
So, if I buy the whole package, and get the included receiver, is there any way to hook up an external antenna to the unit? An external antenna for me is a must.
Old 06-29-2003, 01:06 AM   #5
samr
So I am trying to put all of these co-pilot threads together...
I have 4 different Garmins so I am not interested in another reciever... I can purchase Co-Pilot 2002 original disk and manual for a reasonable price (how do I know if this is legit? Should I make sure it comes with a serial number also?).
Then I would purchase the upgrade for $99... I thought I read that the 2003 version would work with other GPS recievers? Is this correct and would that be any NEMA capable reciever?
samr is offline   Reply With Quote
Old 06-29-2003, 05:45 PM   #6
jshrieve
I would assume not. While I haven't tested myself, this is from the CoPilot 2k3 help file:
Quote:
Can I use a different GPS unit with CoPilot? Why or why not?
There are three main reasons why our software is designed to work with our hardware only:
1. Product quality. [...]
2. Product reliability and safety. [...]
3. Copyright protection. [...]
However, I've used both Cp2k1 and cp2k3 with my Garmin GPS35, but that is only because the GPS35 allows you to enable/disable each type of NMEA sentence is outputs.. with a little toying you can get a configuration that provides CoPilot with the information it needs, but doesn't trigger the "you must use the official copilot gps".
If you have a configurable Garmin, you might be able to get it to work.
I have not tried just turning on all NMEA stuff again since switching to cp2k3.. maybe it'd work.. but the help file suggests not. I don't see why they'd change it. It's their best form of copy protection.
Player: Celeron II 633MHz, 256MB RAM, 20GB IBM 9mm 2.5" Laptop HD (180G/2ms), onboard ethernet/sound/video/tvout, 10"11"x3" case, MPBS1 70W DC-DC PS w/auto-shutdown controller, in-dash lighted switches, 7" NTSC TFT widescreen in-dash LCD, touchscreen, rear-window brake light installed Garmin GPS35 GPS, credit card sized IR remote w/IRMan, mini-wireless keyboard/mouse (sits under seat), PowerMate black knob, MP3s and GPS Navigation (Winamp, CoPilot, SA8.0).
Car: 1993 Nissan Maxima, Black Emerald
jshrieve is offline   Reply With Quote
Old 07-01-2003, 02:10 AM   #7
samc's Avatar
samc
nope I think copilot 2003 is like what $399? and it comes with the receiver. Its not bad considering what OEM nav systems would cost you. I only hate 1 thing about copilot, otherwise its perfect.
Mine needs to be updated.
samc is offline   Reply With Quote
Old 07-01-2003, 03:50 AM   #8
cproaudio's Avatar
cproaudio is on a distinguished road
Quote:
Originally posted by jshrieve
However, I've used both Cp2k1 and cp2k3 with my Garmin GPS35, but that is only because the GPS35 allows you to enable/disable each type of NMEA sentence is outputs. with a little toying you can get a configuration that provides CoPilot with the information it needs, but doesn't trigger the "you must use the official copilot gps".
I have a Garmin GPS16 receiver which is the same as the 35 but just updated with WAAS capability. It is a configurable Garmin receiver. I have tried many different settings but still doesnt work with Copilot. I would much rather use Garmin GPS than Copilot GPS. It locks faster and more accurate
NEW complete and updated My project with 100+ pics on 7-4-03
If you have a Shuttle FV24 motherboard in perfect working condition for sale, please PM me.
cproaudio is offline   Reply With Quote
Old 07-01-2003, 10:44 AM   #9
Typhoon747
I would also like to use the 16 or the 35 but haven been told many times that the Garmin's will not work with CP2k2 or 2k3.
Maybe I will have to start looking for a 35 and test it myself.
2004 F350 Ext. Cab
Old 07-01-2003, 02:20 PM   #10
Raw Wave
Ricky327
Hi cproaudio
Im also using the garmin gps16 on another s/w, its very fast and can even still work while under a tunnel.
One question though? do you have problem on you GPS where it kept reverting back to garmin mode?
I updated the firmware, reset the gps, and switch it to NMEA mode. I also keep loosing signals ever since I left my GPS in the car on a hot sunny day...might be damaged.
TIA
Ricky327 is offline   Reply With Quote
Old 07-01-2003, 11:02 PM   #11
cproaudio's Avatar
I used to use the GPS16 on Garmin's mapsource. It would only do 3D when the GPS is in Garmin mode. I always have to switch the GPS16 from NMEA mode to Garmin. So to answer your question, no it defaults at NMEA mode. It is locks pretty fast compared to my Copilot GPS receiver. The summer here can reach up to 110 here and I think it reaches 130+ inside the vehicle during summer.
Old 07-02-2003, 03:46 AM   #12
jshrieve
I look up again what the proper configuration for the GPS35 w/copilot is and post it.. posted it like a dozen times in the past here, but I forgot it now. Have to check my car computer.
Old 07-02-2003, 03:10 PM   #13
Raw Wave
Ricky327
Thanks for the reply....mine does 3D on NMEA mode, can get 7-8 satellite easy but still unreliable, signals kept droping off for no reason.
I dont think theres a GARMIN mode compatible software out there...ill check out tomtom 2 it might have it.
Old 07-02-2003, 03:14 PM   #14
Raw Wave
Ricky327
Lots of GPS stuff in here, cool receivers :
http://www.navtechgps.com/
might have been posted before...im a newbie in here so be gentle=)
