Old 08-21-2003, 02:42 PM   #1
CoPilot & Opus - Force Shutdown?
I have CoPilot 2003 and a 150W Opus.
If CoPilot is running when I turn off the car, the Opus will not shutdown the computer. Instead, CoPilot prompts to exit now. Anyway to avoid this and force shutdown regardless?
If only winamp or Media Engine is running, the shutdown works fine.
tejesh83 is offline   Reply With Quote
Old 08-21-2003, 03:07 PM   #2
Registered User
gork's Avatar
The best way I found around this kind of a problem is to make the computer Hibernate instead of Shutdown when th epower button is "pressed" by the opus shutdown controller. It's in your control panel / power for 2K or XP.. If you're in 98, your only option is really standby, but that may not be any good since it takes quite a bit more power than suspend to disk hibernate (which is the same as being off)
gork is offline   Reply With Quote
Old 08-21-2003, 03:47 PM   #3
cproaudio's Avatar
I have the same problem. There's no way I can do hibernate b/c half of my periferals wont work after waking up from hibernation. I have reboot after hibernate which defeats the purpose of hibernation. I need a way to force shutdown all the programs like Tejesh is after.
NEW complete and updated My project with 100+ pics on 7-4-03
If you have a Shuttle FV24 motherboard in perfect working condition for sale, please PM me.
cproaudio is offline   Reply With Quote
Old 08-21-2003, 05:27 PM   #4
You could right a background process to look for that window... then force a yes I suppose. Personally I hibernate.
qjones is offline   Reply With Quote
Old 08-21-2003, 05:30 PM   #5
freestyler's Avatar
or you could just go into the Copilot options and uncheck the option to confirm program exit and it works just fine
1997 Jeep Wrangler Rugged Waves
Ebay Stuff For Sale
freestyler is offline   Reply With Quote
Old 08-21-2003, 05:43 PM   #6
I can't find that option.
Are you using CoPilot 2003?
Old 08-21-2003, 06:38 PM   #7
freestyler's Avatar
go to planning mode
then tools then options
Ebay Stuff For Sale
Old 08-21-2003, 07:12 PM   #8
You da man!
I never played with it enough to find Planning Mode. Thanks for opening up the new world of possibilities.
Theres also a lot of other options to customize (ie: show windows task bar). I needed that on my last trip down to florida. It was such a pain closing CoPilot just to change the current playing mp3 using the TouchScreen.
