Old 09-16-2003, 01:28 PM   #1
Registered User
SurfinCajun's Avatar
Reas. Price GPS
I am looking for a GPS unit that is under $100. I would get a Garmin but they are priced a little bit to high for me. Basically I want the best bang for the buck. Any reply's would be appreciated.
SurfinCajun is offline   Reply With Quote
Old 09-16-2003, 01:45 PM   #2
Super Moderator
hijinks21's Avatar
i really like the new eathmate.. its 110
'98 Explorer Sport
80% done
hijinks21 is offline   Reply With Quote
Old 09-16-2003, 03:11 PM   #3
I concur. I got mine for around $120. I had to tell WinXP manually to use the USB-COM drivers provided, but otherwise it's been painless and comfortable. It's nice because it's small and doesn't need an additional power source, I'd highly recommend it.
Too bad Co-pilot doesn't work with it. Hope it will next year!
Sensor is offline   Reply With Quote
Old 09-16-2003, 03:30 PM   #4
the older earthmate serial ones sell for less than 100. i have the even older tripmate serial that sells for about 50 on ebay. the new ultra small ones are like 130 or so. shop around
krystar is offline   Reply With Quote
Old 09-16-2003, 09:59 PM   #5
I found that the new usb earthmates loose the signal a lot for me, and also since they are usb they flip out and act weird if you do a suspend or hibernate. I usually just suspend the computer when I leave the car, and when I come back resume it. when I did that using a usb receiver it wouldnt find it, or it would just say aquiring signal for ever and then sometimes find it. I am going to use a serial older tripmate since the antenna is larger and its more reliable. not as accurate or fast, but at least it would work consistantly.
AlphaFox is offline   Reply With Quote
Old 09-16-2003, 10:42 PM   #6
Suprapc's Avatar
I have a USB earthmate for my notebook it kicks way more butt than my old RandMcnall one did. If you become a registered customer they send you offers all the time in the mail to buy the receiver for 99.xx.
SurfinCajun WOW we have another south Louisiana car pc that is cool I was afraid I was the only one. Shoot me an E-mail sometimes I'd like to see your setup.
2002 Golf TDI With Phatbox . Blue 87 Supra Needs to go, Grey 89 Targa with stock Radio.
Suprapc is offline   Reply With Quote
Old 09-17-2003, 01:53 AM   #7
spectrumzz's Avatar
If you plan to use NMEA v2.0 software with USB-to-serial, get the Deluo GPS. It's under $100 and it gets a lock faster than the Earthmate. On top of that, the drivers work perfectly. It's also USB.
spectrumzz is offline   Reply With Quote
Old 09-21-2003, 11:58 PM   #8
http://www.deluo.com/Merchant2/merch...tegory_Code=GR
Serial or usb, choose your flavor.
ScYThE is offline   Reply With Quote
Old 09-22-2003, 12:25 AM   #9
I comment bout Navroute for loosing signal all the time compare to my garmin and once I also did a try out of Radioshack's serial Gps which was discontinued
both of them works perfect always got 10 lock sat, today I baugth a usb hub just find out that power adapter was not included , went to Ratshack but coudnt find 5 volts so i grab the 6 volts and pray, My Gyro Mouse and KB works
fine check the Navroute GPS I was surprise usually i got 7 sat lock but today got 10 and never lost signal for 1 1/2 driving since its magnet mount and waterproof i installed on top of the roof and got better result.
www.navroute.com to those who wants to try
jeseyboy3 is offline   Reply With Quote
