Old 09-27-2003, 08:23 PM   #1
Anyone else using a recent MS Streets and Trips
I'm using 2004 and for the most part it is more then adequate for what I need right now. However I get the time out error that the program hasn't been able to find the GPS when I hibernate the system. Everytime this error comes up I have to click ok, even though the reciever will reaquire the signal on it's own. If anyone has found a solution to this I would like to know what you did.
adamis is offline   Reply With Quote
Old 09-28-2003, 08:34 PM   #2
I do not have a solution for your problem, but I do have a question. I am using ST2001 and when I use my GPS it only updates the possition about every 12 seconds. Before I go out and buy 2004 I was wondering if it updates quicker and can you have direction up, instead of north up so the map turns on the screen as you go around a corner.
cybuch is offline   Reply With Quote
Old 09-28-2003, 08:36 PM   #3
Super Moderator
hijinks21's Avatar
i dunno about ST but for mappoint there's a 1 second hack and there's probably the same thing for ST
'98 Explorer Sport
80% done
hijinks21 is offline   Reply With Quote
Old 09-28-2003, 08:58 PM   #4
Streets and Trips is a 1 second update. I've used Streets 98 and it also was a one second update. It does do directions, although it isn't voice directions, it highlights a path on the map and provides step by step directions on a sidbar.
One good thing about Streets and Trips 2004 is the resizeable font and the display of stores, restraunts, gas stations, police stations, etc... on the map. I can drive along a street and watch the map for types of stuff I'm interested in.
Old 09-29-2003, 05:57 AM   #5
Super Moderator
hijinks21's Avatar
wow ST 2004 sounds just like mappoint 2002 just without the SDK
'98 Explorer Sport
80% done
Old 09-29-2003, 07:17 AM   #6
chut's Avatar
I've got Streets and Trips 2003 and I really like it. I use it at the same time as Door to Door Co-Pilot and together they work great. Of course I can't connect both to the GPS at once, but thats something I can live with. By finding what I want (like a rest. or city hall or whatever)with streets, I plug the address into Co-Pilot and get the voice commands and full screen prompts to lead me to my destination. I don't have any problem with update delays. It seems to work great and the adjustable fonts on the maps makes my life easier also.
Peter
chut is offline   Reply With Quote
Old 10-01-2003, 04:15 PM   #7
andymitch1971's Avatar
Hi
Ive got mappoint 2002 , which only updates the GPS every 15 secs.
I downloaded this ..."Agps".....http://www.techgt.com/agps/
Now it updates every second and it talks the directions to me, brilliant.
It only works for ten minutes, have to send the author $10 to register.
Worth it though, **** hot add on.....
Regards...
andymitch1971 is offline   Reply With Quote
