Old 10-30-2003, 12:10 AM   #1
USB vs Serial
Well, I've finally decide to get either the Deluo or the Earthmate for my car. I've been using a handheld GPS, and it's simply not permanent or hidable enough. That being said, I'm trying to decide between usb and serial. I've done a little reading here, but other than the recent thread that mentioned serial GPS's don't work with Netstumbler, I haven't found many hard facts one way other the other. Does USB have trouble waking back up after being hibernated or suspended? I have read a couple of fleeing posts making reference to that, but didn't know if it was true for all usb GPSs or just particular ones. I like the USB because of the ease of using one plug and being able to extend it and such, but if it has problems with compatibility and or hibernate/suspend, I'll probably just go with the serial. So, any thoughts one way or the other? Any of you really happy/unhappy with your purchase? Any advice to share?
Thanks,
Taytay
Taytay is offline   Reply With Quote
Old 10-30-2003, 02:00 AM   #2
Raw Wave
Confused's Avatar
I'm pretty happy with my Sapphire GPS, which is currently plugged into a USB2 hub under my dash. It picks up a fix real quick too.
Not had any problems with the mouse coming out of standby/hibernate...only my dodgy VB programming
I've not used any serial GPS devices, but from my experiences with the Sapphire USB model, I probably won't be getting a serial in the future
Garry
Co-Developer of A.I.M.E.E
www.aimee.cc
Confused is offline   Reply With Quote
Old 10-30-2003, 08:19 AM   #3
*DaNut*'s Avatar
i just bought the serial deluo and no proabs here. i use it on my laptop for nav and netstumbler. i just leave it plugged in all the time from house to car.
*DaNut* is offline   Reply With Quote
Old 11-02-2003, 02:11 PM   #4
BoraXP's Avatar
Thanks,
Taytay
i big issue for me is power. USB GPS's power themselves. serial either need batteries or MORE WIRES
i have so many as it is
BoraXP is offline   Reply With Quote
Old 11-06-2003, 03:19 AM   #5
CivicDisturbance's Avatar
Currently using USB. Had no probs at all. Plus points as above, less wires and is self powered.
I have the Hiacom (sp?) HI-203E from Ebay. Locks quick and holds great.
Regards
Chris
CivicDisturbance is offline   Reply With Quote
Old 01-10-2004, 05:59 PM   #6
what software are you using with the hi-203e mate?
peugeot 406 HDI GTX Carputer
shuttle sn41g2,amd2500xp,512 ddr ram
64 meg agp,gps,dvd rom,autoroute 2004
media engine 2.0+other stuff
15" active matrix screen(v nice)
handtrack mouse+mini usb kb,opus 150w
sound wired into car audio system
sparkyuk is offline   Reply With Quote
Old 01-11-2004, 04:00 AM   #7
Raw Wave
Laidback's Avatar
I use MapPoint 2002 with an Haicom HI-203E no problem.
Edit: Ooops, just checked and I've got the HI-202E so scratch the above!! :smacks forehead:
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 01-11-2004, 04:18 AM   #8
LESLIEx317537's Avatar
I would use USB but I got the RandMcNally serial first and for 60 buks.
I'm happy with it, but would rather just plug in 1 usb plug instead of the custom molex I made and then into the serial.
The new NetStumbler when ever he releases it, will support more devices I hope.
RandMcNally works with netstumbler. My old D-Link USB WiFi did also, for like 10 seconds and on and off. (Not supported at all in that release)
Are you planning on WarDriving? lol
Make sure you get powered hubs. I have 1 in front, and 1 in back. 8 ports total.
LESLIEx317537 is offline   Reply With Quote
Old 01-11-2004, 04:26 AM   #9
Raw Wave
Laidback's Avatar
If the GPS outputs NMEA or Garmin protocols, then NetStumbler should support it.
Laidback
Laidback Carputer
Old 01-11-2004, 03:25 PM   #10
I was more refering to the support of non Prism chipset devices. WiFi
Old 01-11-2004, 03:39 PM   #11
Raw Wave
Laidback's Avatar
Well, Why?? it's a GPS thread!
Laidback
Laidback Carputer
Old 01-11-2004, 04:57 PM   #12
MikeH's Avatar
NetStumbler uses a GPS input to plot the Wifi access points it's finds so that you can see them on a map!! Pretty cool stuff.
MikeH
CarNetix
Helpful info at http://www.carnetix.com
C134, M10000, 40GHDD, XM-PCR, CarNetix P2140, FP
MikeH is offline   Reply With Quote
Old 01-11-2004, 08:02 PM   #13
Talking
HAhah, yea. And I'm The Easter Bunny.
