10-30-2003, 03:11 AM
#1
I'am Looking for a better maping software to use with Delorme GPS unit.
Is anyone else using Delorme street atlas 2003 and GPS unit is the U.S. I am looking for a more detailed map that I can use with my Delorme GPS unit.
10-30-2003, 10:37 AM
#2
The new CoPilot will work with any more GPS's and it is awesome, but it is $250. I have a freind who swears by MS Streets.
John
JohnRam
10-30-2003, 10:46 AM
#3
Older versions of copilot can be fooled into using any GPS unit with programmable output. If anyone wants to know how, I'll post the info on it again.
10-30-2003, 11:17 AM
#4
Is street atlas not detailed enough? I don't use it just asking. I use delorme topo usa. it seems to have all the streets up until I get to a parking lot
10-30-2003, 11:41 PM
#5
The people here at GPSPassion.com have a section dedicated to iGuidance. They love it! http://www.gpspassion.com/forumsen/d....asp?CAT_ID=12
They have specifically compared it to Delorme's stuff and declared it crap. Makes me want to try it anyway...
- Taytay
11-01-2003, 12:25 PM
#6
Street atlas 2003 is okay. The one major flaw I dont like is that it sometimes it does not diplay the street name when you appraoch the street. Like at the intersection. It's kinda a drag when your GPS does not show you what street you are on. I heard that the street atlas 2004 they correct this problem. Isn't copillot only used on the handheld devices and not windows?
Opus case. MB 899 core duo 2.0ghz
Dual vga out, 400 gb hard drive, Centrefuse front end
zapco 1000.4 for zapco 6.5 componets
zapco 1100.1 for 2 13" W6.
11-01-2003, 02:08 PM
#7
Actually, Copilot is for both Windows and the Pocket PC.
Cheers,
Taytay
11-03-2003, 08:46 PM
#8
Software
Personally, I use MS Streets & Trips 2004 w/my Earthmate USB. It needs some updating (doesn't have the latest street names/redesignations since my home town moved the city limits, or the college I go to), but it does most of what I ask it to.
Later.
nedry OUT
11-07-2003, 09:30 PM
#9
The people here at GPSPassion.com have a section dedicated to iGuidance. They love it! http://www.gpspassion.com/forumsen/...t.asp?CAT_ID=12
- Taytay
I've seen this also. Is anyone on this forum using iGuidance? It seems that everybody that would ask off another brand of gps the moderaters on that forum would butcher what ever it is if it is not iGuidance. It looks okay but I've only seen the pocket PC ver.
11-07-2003, 10:04 PM
#10
I have both Delorme and MS S&T 2004. I like Delorme because of all the info it shows like speed and I like the arrow instead of just the car MS uses. I like MS thought because I can get a big easy to read map without much other stuff on the screen.
I'd love to get copilot but with a new baby at home I can't afford $250 for it. Are any of you running the newest version that just came out this month?
Does anyone know if you can get more info out of MS like speed? I don't see any real gps options in it.
1992 525iM - 1989 325is - 1993 525iT
7.4" Lilliput w/touch, M10000. GPS, TV, DVD, WiFi.
11-08-2003, 01:58 AM
#11
There's an addon you can get called AGPS (I think?) or something like that that goes on top of MS S&T. It apparently makes it more gps friendly.
-Taylor
11-08-2003, 03:07 AM
#12
-Taylor
http://www.techgt.com/AGPS/
Supposedly it's really great.
A friend of mine swears by it. He says he finds the MS map software a waste of time by itself, but with AGPS, it's actually useful. It gives speed, heading, time etc. He says it's one of the only pieces of software he's been happy paying for.
(I haven't used either S&T or AGPS myself, just going by what he says.
(Edit: Supposedly, AGPS works only with Mappoint, from what I can tell. I don't remember what software he's running.)
Though I am interested, is Copilot worth the money? I'd like small buttons, so there's more room for the map. Also, what does or doesn't work in Canada? All the major mapping software works in Canada? (I'm sure I could search, but since this thread is about mapping....)
Regards,
Kris
11-08-2003, 02:34 PM
#13
Regard
Hay Brodee, Which one has a more detailed map as far as diplaying street name points of interest (ATM's, gas stations, Resurants etc...). Are you using delorme gps receiver?
10-01-2004, 04:20 PM
#14
Later.
nedry OUT
I was curious, did you have to do anything special with your setup to get the Delorme to work with Streets and Trips 2004? I heard that the Earthmate isnt NMEA compatible or whatever, which allows it not to be used with certain software.
Does anyone know if this is an issue with Earthmate and S & T 2004?
thanks
10-01-2004, 05:31 PM
#15
First off, do you have the serial or USB version? There is a BIG difference in compatibility w/ software. If it is USB I highly suggest iGuidance/Routis.
| Thread Tools |
| Display Modes |
Linear Mode
