The MP3car.com Store
Thread Tools Display Modes
Old 11-20-2003, 01:36 PM   #1
MeanGT's Avatar
Vehicle: 1993 Acura Vigor
My Photos: (0)
Earthmate not compatible with Mappoint
Just so everyone knows and doesn't repeat the same error I made, the Earthmate USB receiver is not NMEA 2.0 Compliant, which means that it is incompatable with Mappoint. Which in turns mean it doesn't work with Coyote's Mediacar GPS setup.
I was lucky that I hadn't opened the Shrinkwrap on the included software with my earthmate I bought from Comp-USA otherwise they would not have allowed me to return it. I exchanged it for a NAVMAN (which was $10 anyways) and it works great!!!
My OLD Carputer: http://www.mp3car.com/vbulletin/showthread.php?t=17412
Currently, Don't have a carputer :( I sold my lincoln and bought a '93 Acura Vigor, plan on putting a carputer in it one of these days. You can see my vigor at: This Site
MeanGT is offline   Reply With Quote
Sponsored Links
Old 11-20-2003, 02:32 PM   #2
Super Moderator
hijinks21's Avatar
Vehicle: 98 Exporer Sport
My Photos: (0)
ahhh my earthmate works just fine with mappoint 2002 and 2004.
'98 Explorer Sport
80% done
hijinks21 is offline   Reply With Quote
Old 11-20-2003, 02:57 PM   #3
MeanGT's Avatar
My Photos: (0)
really? the USB earthmate? When I tried to use it with Mappoint 2002 it said that the data stream was not NMEA 2.0 compliant or something like that. hmm, oh well,
Old 11-20-2003, 03:24 PM   #4
Super Moderator
hijinks21's Avatar
My Photos: (0)
you installed the drivers for the earthmate and then selected the option for it to be used with apps other then SA?
'98 Explorer Sport
80% done
Old 11-20-2003, 03:32 PM   #5
MeanGT's Avatar
My Photos: (0)
yup,, mappoint even recognized it on COM5. But thats ok, my NavMan works pretty good, (although it's reportedly not as accurate)
Old 11-20-2003, 03:58 PM   #6
spectrumzz's Avatar
Vehicle: 1994/Nissan/300ZXTT
My Photos: (0)
This doesn't work for the majority of people, including me, because the stream is technically not NMEA compliant, and the Earthmate folks don't seem to care because MapPoint is a competing product. I'm not sure how the individual on this forum got the USB Earthmate to work, because as far as I have seen, it doesn't.
spectrumzz is offline   Reply With Quote
Old 11-20-2003, 04:02 PM   #7
Super Moderator
hijinks21's Avatar
My Photos: (0)
yes the NEW earthmate is nmea compliant. Check the website for yourself. I have done a ton of gps work and i've even snooped on the com port and its all valid nmea strings
'98 Explorer Sport
80% done
Old 11-21-2003, 08:32 AM   #8
CoolDaddyAndy's Avatar
Vehicle: 1998 Ford Taurus
My Photos: (0)
Earthmate is crap, delorme is becoming more and more sh1ttee with every version of there software and I would guess they skimp on the hard ware as well. read the reviews for the delorme software on epinions or amazon and common sense will show you not to purchase delorme stuff anymore.
CoolDaddyAndy is offline   Reply With Quote
Old 11-21-2003, 04:41 PM   #9
Vehicle: 2002 BMW 320 TD
My Photos: (0)
The GPS Delorme Earthmate USB is compatible NMEA.
I had many problems to make it work with the USB cable.
I have manufactured myself a cable for the serial port and I no longer have any problem.
Mappoint, Destinator, AutoRoute and other programs work me OK.
The problem is to use the same connector of the USB cable, but it is possible.
If somebody needs information to make the cable I can give it.
Greetings
Note: Sorry for my English
En espaņol:
El GPS Delorme Earthmate USB es compatible NMEA.
Yo tuve muchos problemas para hacerlo funcionar con el cable USB.
Me he fabricado un cable para el puerto serie y ya no tengo ningun problema.
Mappoint, Destinator, AutoRoute y otros programas me funcionan OK.
El problema es el mismo conector del cable USB, pero es posible.
Si alguien necesita informacion para hacer el cable se la puedo dar.
Saludos
Nota: perdon por mi ingles
New_Compact is offline   Reply With Quote
Old 11-24-2003, 09:52 PM   #10
Vehicle: 2003 Sentra Spec-v
My Photos: (0)
I dont know what you guys are talking about. I have the new WAAS Enabled USB GPS from Delorme and it has worked with EVERY program I have tried it with. (Streetfinder, Streets and Trips, Even USA PhotoMaps, which is a freeware app that only works with Serial gps)
If you download the USB to Serial drivers from Delorme's webpage... it should and will most likely work with any GPS app.
If you have any questions, you can ask me. I have messed with this thing non stop for the last week and a half!
Click Here to see my Car's Website
2003 Nissan Sentra Spec-V
Spec-V is offline   Reply With Quote
Sponsored Links
Old 12-02-2003, 06:10 PM   #11
spectrumzz's Avatar
My Photos: (0)
Sounds like there must be new drivers, because when I owned the DeLorme I spent endless hours on the USB to Serial driver trying to get it to work. And yes, I was able to get the NMEA stream but it would send data that was slightly mis-formatted. Most apps would work, but mappoint and a couple of others would not.
Old 12-06-2003, 06:41 PM   #12
wi77iam's Avatar
Vehicle: 2004 Subaru WRX STi
My Photos: (0)
I installed Mappoint 2004 and connected my usb Earthmate with the usb-to-serial drivers supplied by DeLorme. MP detected the earthmate but then I got the error saying the data was being received but it wasn't NMEA compliant. Then I installed AGPS, the COM add-in for MP. When I set up AGPS to recognize the earthmate, it immediately locked on and everything was working fine. Then I turned off AGPS and tried to track with just MP. It also started tracking with the earthmate.
I'll keep using AGPS though because it has autorouting and voice prompts.
wi77iam is offline   Reply With Quote
Old 12-08-2003, 07:39 PM   #13
Vehicle: 99 Mitsubishi Eclipse
My Photos: (0)
im having the same problems with my new earthmate that i just got.
what is AGPS? that might help my situation.
thanx
james
siueclipse is offline   Reply With Quote
Old 12-08-2003, 09:37 PM   #14
wi77iam's Avatar
My Photos: (0)
AGPS is an add-in to MapPoint. It enables autorouting and voice prompts, plus display of speed/heading. Well worth the $10.
Old 12-12-2003, 11:54 AM   #15
rgardjr's Avatar
My Photos: (0)
Here is my experience with the latest version of the earthmate gps receiver. I got it to work with the Destinator SDK and with Mappoint '02. The hardest part of the process was to get the Com Port configured correctly. Here's the process that you have to go through:
1. Download and install the third party USB to serial drivers from delorme from here: ftp://www.delorme.com/Downloads/USBEmate.exe Some instructions can be found here: http://www.delorme.com/support/gps/u...=&P=17111&C=28
2. On both machines (Win XP Home) I installed the drivers on I ended up with a Human Interface device and not an Earthmate USB receiver under the com ports in the system config. Correct this problem following these instructions: http://www.delorme.com/support/gps/u...=&P=17111&C=28
After this I checked my com ports and I showed the earthmate receiver installed on com 5 on the first machine. I changed the baud rate to 4800. Then I fired up the destinator sdk which didn't list com 5 as an choice in the GPS Status>Settings menu. It only gave me a choice of com 1 or com 3. Kind of reminded me of the old days dealing with modem set up. After much messing around uninstalling and reinstalling com ports here is what worked for me. In the control panel change the earthmate gps to com 1 which already had a serial port installed on it. Change the com 1 serial port to a different port that is not in use-com 5 or whatever. Fire up destinator and configure to com 1, 4800, MNEA and save settings. Reboot the machine and now when you start destinator you should be working. After this I tried Mappoint '02 with the AGPS helper program. I configured the GPS to com 1, 4800, MNEA in the AGPS utility and everything was working great. I hope this might help some one out there who's having some problems getting up and running. I had to do this same process on my carputer as well. I'm using my laptop to troubleshoot and make software selection decisions until I get my carputer installed.
rgardjr is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
