Old 11-25-2003, 11:16 AM   #16
Well just make sure you have disconnected the power coming from the usb port or you may end up back feeding the MB, which in turn may draw more current....
ALIBABA - I30 99
Nemiah M10000, C134
DVD, 40Gig, 256MB DDR
GPS, OBD 2, Reverse Cam
Mute on stereo w I300 car kit
Liliput 7in w usb touch screen
Direct connect with BOSE-CD changer
skassama is offline   Reply With Quote
Old 11-25-2003, 12:04 PM   #17
MeanGT's Avatar
yeah, the only two wires that actually run to/from the USB port are the data wires, I was aware of that potential problem so I took precautions.
My OLD Carputer: http://www.mp3car.com/vbulletin/showthread.php?t=17412
Currently, Don't have a carputer :( I sold my lincoln and bought a '93 Acura Vigor, plan on putting a carputer in it one of these days. You can see my vigor at: This Site
MeanGT is offline   Reply With Quote
Old 11-27-2003, 04:16 PM   #18
cvi
Does anybody know if a powered usb hub will do the same thing?
MeanGT, what wires would i have to splice into to do it "your way"?
cvi is offline   Reply With Quote
Old 12-02-2003, 02:48 PM   #19
cvi
anybody ?
Old 12-02-2003, 03:12 PM   #20
Raw Wave
Laidback's Avatar
+5v and GND. Usually red & black....see this link http://www.hardwarebook.net/connector/bus/usb.html
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 12-02-2003, 03:56 PM   #21
cvi
Thanks laidback
What about the powered usb hub, would that keep the gps locked up? If thats the case, i wouldnt wanna splice into the gps, just keep the usb hub powered.
I might be able to wake up the pc with touchscreen or keyboard this way?
Old 12-02-2003, 06:39 PM   #22
LESLIEx317537's Avatar
Awesome idea!
I hated waiting a long time to get a GPS fix, specially when I was showing off the CarPC to someone.
Do you think it will work with the Rand McNally Serial one?
LESLIEx317537 is offline   Reply With Quote
Old 12-02-2003, 06:56 PM   #23
ddogg_777's Avatar
So, I take it you now have the gps connected to an accessory 12V line or is it always on (battery 12V)?
ddogg_777 is offline   Reply With Quote
Old 12-02-2003, 07:01 PM   #24
It has to be a line where 12 volts is supplied to the regulator no matter what key the position is in.
So the Constant On / or the Battery run is fine. I'll use the battery run line before it goes into the shutdown controller.
Old 12-02-2003, 07:03 PM   #25
ddogg_777's Avatar
I see, well, just add a switch to cut the power if you have your car sitting for long periods of time.
I like the idea!
Old 12-02-2003, 07:04 PM   #26
spectrumzz's Avatar
The GPS might kill your battery no? Any idea how many watts the GPS + the USB hub are going to eat up?
spectrumzz is offline   Reply With Quote
Old 12-02-2003, 07:12 PM   #27
Quote: Originally Posted by MeanGT
It draws 120-135 milliamps depending on what its doing, and the heatsink barely gets warm at that level.
That's very little. Don't be skurd your batt will die.
Old 12-02-2003, 07:24 PM   #28
ddogg_777's Avatar
Sounds like the GPS takes 1 Watt if it's 120 mA. I was just saying if your car will be sitting for weeks....I DON'T KNOW!!
Old 12-02-2003, 07:30 PM   #29
Would you let your 300HP STi sit for weeks?
My car begs to be driven.
Old 12-02-2003, 07:37 PM   #30
ddogg_777's Avatar
