The MP3car.com Store
Thread Tools Display Modes
Old 11-22-2003, 02:15 PM   #1
My Photos: (0)
a new way of GPS
I looked through the posts in this forum but didn't find anything about a GPS board. So I googled and find some results. I think some of you guys may be interested.
I am working on my carpc and I want to make the GPS builtin instead of external. I am putting my car-pc in a single DIN, so I hope to put the GPS unit into the DIN too. Hopefully, I found some GPS boards with serial port, so i think i can connect it to my car-pc using a modem wire. And it has an antenna connector, capable of using both passive and active antenna. I am thinking about using the antenna of my car, but I am not sure if that works. I didn't do much research into antenna yet, but maybe that is possible.
And another great thing is that this board is really cheap, I find one guy on ebay who is selling superstar board at $49.00, but I find it a little doubtful, as the connector type is different from what I find from other places.I am bidding on it right now, and I may post about it when I get it.
The link is right here:
NovTel superstar GPS board:
http://www.novatel.com/Products/superstar.asp
and there are several other kinds such as: Jupiter GPS OEM, GPS955, G 12 GPS board from Ashtech. etc... You guys can google on these. I haven't looked much into those.
brownpage is offline   Reply With Quote
Sponsored Links
Old 11-22-2003, 02:28 PM   #2
Naamanf's CarPC Specs
Naamanf's Avatar
Vehicle: 2007 Tahoe, 1979 Pontiac Trans Am, 1971 Hemi 'Cuda
My Photos: (0)
You would be much better just getting a all in one USB unit. You can't use your car antenna for the GPS, and most all-in-one units are the size of an antenna any way. So they are actually smaller than a board+antenna. And they are the same price if not cheaper when you get the price of the board combined with the antenna.
2007 Tahoe
Opus with iBase 896 and Pentium M 735 Transflective Xenarc Alpine DVA-9861, PXA-H900, Sinfoni 45X2 (2) 90x2, Genesis Dual Mono, JL 1000/1 (2), Focal Be tweeters, ScanSpeak Revelator Mids, Dynaudio MW170, Dayton 12" Ref.
My Install
Naamanf is offline   Reply With Quote
Old 11-22-2003, 04:12 PM   #3
My Photos: (0)
So, what's the difference between a car antenna and a GPS antenna? I am no electric technician so sorry for the ignorance. I thought that they both receive signals, only frequency differs. And GPS frequecny is 1575.42 MHz, while FM radio has a frequency of ~ several hundred MHz. So GPS frequecny is not too much different from a radio frequency. So maybe their antenna design is simiar?
But, maybe GPS antenna is not only an antenna, but also includes filter or something else. In that case, it can't be replaced by normal car antenna.
Thanks for advices.
Old 11-22-2003, 09:45 PM   #4
Naamanf's Avatar
My Photos: (0)
Thanks for advices.
FM radio is in the 90-110 mhz range. The size of the radio waves is very different. And in simple terms the size of the wave (due to it's frequency) will determine the size of the antenna. The lower the frequency the larger the antenna.
2007 Tahoe
My Install
Old 11-23-2003, 10:47 AM   #5
My Photos: (0)
Thanks a lot for the explanation. Yes, FM radio is 90-110mhz range. And that means FM wave has a wavelength of about 3 meters. And for normal AM radio, the range is 535khz-1.7Mhz, that means AM wave has a wavelength of about 300 meters. So we need to pull out car antenna to get better reception of AM signal, which is often not so good.
Then, for GPS, which has a frequency of 1575.42Mhz, that means a wavelength of about 0.2 meters. This is not a so small length compared with the size of car antenna. As we can pull out the antenna to get better reception of AM radio, we may also retract the antenna to get better GPS signal. And, actually I often let my antenna stay very short and the Fm reception is still fine.
no intention to bother. THanks a lot for reply. That makes me more practical on the antenna issue.
Old 11-24-2003, 03:16 AM   #6
Registered User
felix99's Avatar
Vehicle: 2000/Renault/Clio2-commerciale
My Photos: (0)
Yu will not receive anything with a gps connected to your radio atenna - its more different than you think - You absolutely need a GPS antenna for a gps card - So if you don't want do be dissapointed get you a normal standart USB GPS . Its very small - or get you if youa bsolutely want your module a combo antenna for FM/AM / GPS - these have 2 antennas integrated one for radio one for GPS.
Shortwave is diffenret from microwave ! Shortwave signals are stronger than GPS signals which explains that you can receive them +/- properly -
Get a usb gps
regards
felix
=>> Carpc Version2 -- Epia M 10K based<<=
::Epia M10k,7"VGA/40GB2.5",GPS,Opus90W ::
::trying to build second low cost carpc::
::Automp3.de :: CAR= Renault Clio2 - 2 seats 1.9D
felix99 is offline   Reply With Quote
Old 11-25-2003, 09:54 AM   #7
My Photos: (0)
Get a usb gps
regards
felix
I see. Thanks a lot, man.
I will get a usb GPS then.
Old 11-29-2003, 08:31 AM   #8
DodgeCummins's CarPC Specs
DodgeCummins's Avatar
Vehicle: 96 Dodge Ram 2500 Cummins Diesel (turned up)
My Photos: (20)
The other factor for the antenna is polarization.
A surface radio antenna has vertical polarization (the transmitting antenna is straight up and down...so the waves go up and down).
Most satellite based transmissions use circular polarization.
Your car antenna uses Vertical Polarization.
So yes, you can shorten your AM antenna to match the wavelength, or 1/2 or 1/4 wavelength of the GPS signal; but your polarization is wrong.
If you took a circuit board and etched out a circular antenna that had the correct wavelength, that would probably work.
current projects
DodgeCummins is offline   Reply With Quote
Old 08-24-2004, 02:51 PM   #9
My Photos: (0)
What if your car had a gps antenna fitted, but no gps unit? Could you use the antenna from that?
pioneer is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
How to make the Garmin GPS 35 Work with Copilot 2003 fluffy2097 GPS 16 09-05-2007 04:19 PM
Cant get good GPS signal in car. Ricky327 GPS 8 01-29-2004 09:28 PM
GPS Interferes with DSCustoms Touchscreen! Help! gork LCD/Display 4 09-04-2003 09:20 AM
Music and GPS Michael Szilagyi GPS 1 02-28-2003 02:26 AM
GPS Recommendations.. Karnth GPS 3 06-13-2002 09:57 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
