HELP!
I'm trying to setup a Haicom 203E serial on my laptop along with infomap navigator. I think I've firstly managed to get around the computer recognising the receiver as a mouse, simply by disabling the mouse from device manager.
I then checked the baud rate under setting within Infomap Navigator and proceeded to use the option 'Track GPS'. When I run this option I receive the message "GPS data out of map boundaries".
Once I clik OK to this, I am finding that I can't receive a signal and no satellites are appearing?! Could it be because I'm using the receiver within the house (im thick when it comes to GPS!!)? Its too cold to go in the car, LOL! but tried hanging it out the window
Also, there is a red LED flashing on the receiver - should this be flashing? Should I have installed any drivers once I had disabled it from within device manager? I've noticed some people mentioning that the receiver may require a certain amount of power to work. The only power it can be running off is from the PS II port?!
Any help will be well appreciated!
