Quote: Originally Posted by magno
I was wondering what GPS unit someone you use to connect to Destinator SDK since I havent had any luck connecting my ancient Trimble.
Thanks Magnus
I use a Fortuna U2.
Strange that you can't get Destinator to see it, Destinator works with most any receiver. Have you verified that you can see the NMEA strings on the serial port without Destinator, eg by connecting to the port with Hyperterminal?
When you've got that working, then use those same settings in Destinator. Destinator should scan and detect though.
