Old 01-17-2004, 03:23 PM   #1
GPS Antenna with RG174 cable
I found a GPS antenna that has a 5M RG174 cable for connection. Would something like this work for a PC based GPS? If so, what type of hardware is needed to support the RG174 cable input?
audrenaline is offline   Reply With Quote
Old 01-17-2004, 03:25 PM   #2
robiewp's Avatar
a soldering iron and some patience
Use the source, Luke.
car computer rev 3: 8" lilliput and usual suspects
robiewp is offline   Reply With Quote
Old 01-19-2004, 11:55 PM   #3
Maybe all you're looking at is an external antenna to connect to a GPS unit, which won't get you very far. RG174 is just a coax cable for RF signals. If thats the only connection, it doesn't sound like you're looking at a complete GPS.
The GPS units I'm aware of have RS-232 or USB connections for the PC (and maybe a power connection), or a connector like an RJ45 on the Garmin GPS-16 I have which required me to build an interface cable to hook it to the com port on the PC. A GPS unit designed for a separate antenna might use RG174 as the cable between the GPS electronics and the antenna.
Alanh is offline   Reply With Quote
external gps and aprs vehicle tracking swingwally GPS 12 10-23-2004 03:33 PM
a new way of GPS brownpage GPS 8 08-24-2004 03:51 PM
GPS Interferes with DSCustoms Touchscreen! Help! gork LCD/Display 4 09-04-2003 10:20 AM
A cable I found. masterful LCD/Display 5 08-17-2003 10:36 PM
Cat6 cable -> IDE Cable dan0myte General Hardware Discussion 8 08-31-2001 09:29 AM
