Old 02-04-2004, 04:44 AM   #1
New_Compact is on a distinguished road
Earthmate USB to Serial cable
Hi,
I have received several e-mails asking about the serial cable.
This is my experience with this cable:
Ask the technical service of Delorme for to construct myself the cable and this was the answer.
De: Brian Riendeau
Fecha: 10/14/03 20:45:17
Para: 'jose*****@******.com'
Asunto: RE: Email Support Site Form
Hi,
The GPS does not output anything that is compatible with a standard
serial connection regardless of how you wire it. It outputs a binary data
stream per USB specification. The USB to Serial adapter cable actually has
a microchip built into it that converts the binary data to an output that
can then be routed down a serial cable for use with PDAs and other devices
that require a NMEA 0183 compliant signal and have no USB port.
Thanks,
Brian
After this answer I went to Delorme's page and buy the serial cable but
I had an error and they sent the cable to me for a PDA ( palm m500 ).
I live in Spain and for me the shipping charges are more expensive than the cable.
Then i open the cable and surprised I don´t saw any microchip. Look up the pins
Of the connector of the PDA and translate them to a connector of the serial port.
The cable is working perfectly with 5 meters length.
And this is the wiring of the cable:
Cable USB GPS Delorme Earthmate
Conector GPS Conector USB
1 ----------------------- 4 - USB - GND
2 ----------------------- 3 - USB - DATA +
3 ----------------------- 2 - USB - DATA -
4 ----------------------- 1 - USB - + 5 VDC
12 malla ---------------- masa conector (shield)
Cable Serial GPS Delorme Earthmate
Conector GPS Conector D9 Hembra (D9 female)
1 - 9 ------------------- 5 - GND
4 ----------------------- 1 - + 5 VDC interior PC cable rojo *
5 ----------------------- 3 - <- TXD
6 ----------------------- 2 - -> RXD
7 ----------------------- 4 - <- DTR
* Power supply from inside of PC (hacked). When you switch on the PC you
have main power and the GPS start to seeking satellites.
- Use the USB cable for reference for the pins of the GPS.
- For me is working perfectly whith any GPS software. I don´t use
the software supplied with the GPS (USA) because i live in Spain.
Sorry for my english!
Car: BMW 320 TD (Compact E-46 2002)
Motherboard: VIA Epia M10000
Display: Lilliput 7" from DIGITALWW
Power Supply: Opus Solutions SFX-12-15
GPS: Delorme Earthmate USB with serial cable
Software: XP pro, MediaCar, Mappoint, Destinator2
New_Compact is offline   Reply With Quote
Old 02-05-2004, 05:37 AM   #2
Raw Wave
Laidback's Avatar
Laidback is on a distinguished road
Quote: Originally Posted by New_Compact
Hi,
De: Brian Riendeau
Hi,
Thanks,
Brian
Well, AFAIK you can't convert USB data to serial without some sort of Chip/software to control it, so I'd say that you have a serial GPS mouse (otherwise why pins 5-9 etc?) that is converted to USB and by wiring to the pins you have you are by-passing the USB conversion! I may be wrong here!
But well done for finding that!
By the way, what area are you in? We're skiing next week at Sierra Nevada, woo hoo!
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 02-05-2004, 06:57 AM   #3
Hi,
I live close to Barcelona. Normally I go skiing to Cerler ( Huesca's Pyrenees ).
In this season I have 20 days of ski.
Old 02-12-2004, 03:42 PM   #4
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
Can you explain a little clearer I mean pin to pin connection?
Delor USB pin ------ Serial pin
1 --------------------??
2 --------------------??
3
4
5 GROUND
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 02-13-2004, 05:02 PM   #5
rgardjr's Avatar
rgardjr is on a distinguished road
3
4
5 GROUND
I'll try and help. If you're asking about which USB pin goes to which Serial pin-it doesn't work like that. If you have a newer earthmate, you can see that the end of the cable that plugs into the GPS receiver has 12 pins. With a USB cable 5 of these pins are used. To use the GPS via serial 7 of these pins are used. The two cables use the same pins for power, gound and shield, but that's where it ends. The GPS data to and from the receiver is transferred using different pins because of the difference between the two standards. Can you make a serial cable by cutting up a serial cable and the Delorme USB cable-maybe. If the Delorme USB cable has wires going to all 12 pins than it's as easy as finding the wire that goes to pin 1 in the Delorme cable and connecting it to the wire that goes to pin 5 on the serial cable. You'd just follow the pinout that New_Compact provided:
Delorme Serial
Pin Pin
1----------5
9----------5
4----------1
5----------3
6----------2
7----------4
12--------Shield
I haven't cut open the USB Delorme cable, but I'm guessing that there might not be wires running to those pins used for the serial operation. I bought the serial cable from Delorme for $35 and it has worked perfectly to solve my hibernation problem that I had with the USB cable and USB to serial drivers. If you do cut open your Delorme USB cable, let us know if the wires are there for the serial pins.
rgardjr is offline   Reply With Quote
Old 02-20-2004, 05:38 PM   #6
kalito's Avatar
kalito is on a distinguished road
has anyone try this as well? if so.. can you tell me if it works or not... thanx in advance.
kalito is offline   Reply With Quote
Old 02-20-2004, 06:23 PM   #7
rgardjr's Avatar
I'm pretty sure that New Compact has done this. Here's the original thread:
http://www.mp3car.com/vbulletin/gps/18929-earthmate-not-compatible-mappoint.html
My only concern would be that the USB cable that comes with the Earthmate doesn't have wires running to the serial pins on the plug which would complicate the needed splicing quite a bit.
Old 02-23-2004, 03:55 AM   #8
kalito's Avatar
Talking
can someone tell me if the image is correct or is it the opposite way
Old 02-23-2004, 04:29 AM   #9
Raw Wave
Laidback's Avatar
http://www.hardwarebook.net/connector/bus/usb.html
http://www.hardwarebook.net/connector/bus/usb_tech.html
Laidback
Laidback Carputer
Old 06-04-2004, 06:51 PM   #10
Raw Wave
rando's Avatar
rando is on a distinguished road
How to make a serial cable for the USB Earthmate
I just did this (from information posted elsewhere) and it works. It's true, the GPS to USB cable DOES NOT have all the wires you need to get a serial connection. But, if you look close at the GPS end of the GPS/USB cable, you will see that the connector is easily disassembled with a couple of clips. Once inside, all 12 pins are exposed and more than long enough to solder the extra wires you need. I will post pics of this when I get home.
Here is what I did to test it out. I plugged in the USB cable to the GPS and to the computer so that i would get power and ground. There were no drivers installed on this machine ... I'm only doing this to get power and ground. Next I loaded up hyperterminal and pointed it to com1/4800/8/n/1. Finally I plugged in a serial cable to com1 and shorted pin 2 (READ) to pin 6 on the GPS. I immediate began receiving the GPS data stream below.
$Version 231.000.000ES-01501
$TOW: 0
$WK: 1192
$POS: 6378137 0 0
$CLK: 104538
$CHNL:12
$Baud rate: 4800 System clock: 24.553MHz
$HW Type: S2AM
$Asic Version: 0x23
$Clock Source: GPSCLK
$Internal Beacon: None
$LED Flash rate : OnTime: 0 , OffTime: 0
$GPGGA,235948.000,0000.0000,N,00000.0000,E,0,00,50 .0,0.0,M,0.0,M,0.0,0000*77
$GPGSA,A,1,,,,,,,,,,,,,50.0,50.0,50.0*05
$GPRMC,235948.000,V,0000.0000,N,00000.0000,E,0.00, 0.00,091102,,*1E
2004 4runner
rando is offline   Reply With Quote
Old 06-10-2004, 04:51 PM   #11
Mellman
you know, its sad....bout 4 years ago i paid $45+shipping for a serial -> usb cable for my carputer.
Mellman is offline   Reply With Quote
Old 06-15-2004, 11:31 AM   #12
MySQL Error
MatrixPC's Avatar
Rando, can you post the pic? I want to see what I can do to make mine as serial.
Old 06-23-2004, 02:17 AM   #13
Raw Wave
rando's Avatar
Sorry, the digicam is out of town with the lady. No matter, it's simple enough you don't really need a picture.
Just snap off the cover on the GPS end of the GPS<->USB cable that came with the Earthmate. You will see all 12 pins in there. Look at the existing wires and match them up to the pin numbering scheme below. The existing USB connections are in bold.
Delorme Earthmate II GPS - Pinout
1 - GND
2 - USB Data+
3 - USB Data-
4 - +5V
5 - RS232 RXD
6 - RS232 TXD
7 - RS232 DTR
8 - +5v
9 - GND
10 -
11 -
12 - SHIELD
Here is the pin-out for a DB9 serial connector.
RS232 DB9 - Pinout
1 DCD Data Carrier Detect — Input status Line
2 RxD Receive Data — Receives bytes into PC
3 TxD Transmit Data — Transmits bytes out of PC
4 DTR Data Terminal Ready — Output status line
5 SG Signal Ground
6 DSR Data Set Ready — Input status line
7 RTS Request To Send — Output status line
8 CTS Clear To Send — Input status line
9 RI Ring Indicator — Input status line
Solder the GPS TxD line (pin 6) to the DB9 RxD line (pin 2); the GPS RxD line (pin 5) to the DB9 TxD line (pin 3); the GPS pin 7 to the DB9 DTR line (pin 4); GPS GND (pin 1 or 9) to DB9 SG line (pin 5).
Next you need to supply a 5v source to GPS pins 4 or 8 (your choice). The simple thing to do here is just use the USB cable for power. To avoid confusion, you might want to lift the USB Data+/- pins in that case or make a USB power passthrough cable that only passes the +5V and GND signals but not Data+/-. Alternatively you could attach a standard PC molex connector.
That's it. As soon as the device gets power it will start to pump out an NMEA stream 4800/8/n/1. I believe the device will go into sleep mode if DTR goes low. By default, your PC will assert DTR high anytime the COM port is opened so (in general) you don't really need to worry about it.
If you still need pics, I should be able to take some next week.
2004 4runner
Old 07-13-2004, 10:28 PM   #14
asci01's Avatar
asci01 is on a distinguished road
1 - GND
2 - USB Data+
3 - USB Data-
4 - +5V
5 - RS232 RXD
6 - RS232 TXD
7 - RS232 DTR
8 - +5v
9 - GND
10 -
11 -
12 - SHIELD
RS232 DB9 - Pinout
5 SG Signal Ground
Any luck with the pictures, please?
asci01 is offline   Reply With Quote
Old 07-13-2004, 11:55 PM   #15
Raw Wave
rando's Avatar
Ha! I completely forgot. I'll try to put some up tonight.
2004 4runner
Help With Earthmate USB to Serial Conversion rgardjr GPS 3 02-03-2004 09:13 PM
Delorme Earthmate USB with CoPilot 2003 JoeMac GPS 17 09-10-2003 05:01 PM
USB to serial Sleeka General Hardware Discussion 2 12-24-2002 04:55 PM
hmm anyone up for building their own usb 2 serial oddcomp General Hardware Discussion 2 10-21-2002 02:11 PM
APC serial cable pinouts bombboyer General Hardware Discussion 4 08-07-2002 06:13 PM
