Old 02-25-2004, 09:52 AM   #1
kovan is on a distinguished road
RAND McNally and Map Point 2004 - anyone got it working?
Hi all, I am having a small issue,
I have hooked up my gps to the pc and using Hyperterminal i am able to read NMEA sentences just fine, everything works.
when i hook it up to Map point 2004, it says "Initializing" and it never finds the current location,
Map Point states that the gps reciever must be NMEA 2.0 compatible and i did check the reciever specs, it says its NMEA 2.0 compatible.
i am just wondering waht i am doing wrong.
i do no thave any other software other than map point to test it
if anyone had issues, assistance would be appreciate it
Kovan,
kovan is offline   Reply With Quote
Old 02-25-2004, 10:30 AM   #2
wi77iam's Avatar
wi77iam
How do you connect the gps to the pc - is it usb or serial? If usb, do you have a usb-serial driver that makes it appear on a comport? Mappoint needs to see the gps on a comport.
wi77iam is offline   Reply With Quote
Old 02-25-2004, 10:39 AM   #3
the gps is serial,
and yes the map point sees the port because when i go to "configure GPS" it lists the port the gps is on, so it has no problem detecting that there is a communication port that is avaialbe (and only shows it if gps is connected)
the problem is that map point is not getting the signals
Old 02-26-2004, 10:36 AM   #4
yuprules is on a distinguished road
Exclamation Did you change it to NMEA on your GPS unit?
Quote: Originally Posted by kovan
the gps is serial,
I notice you have been configuring your software over and over, have you actually configured your GPS to send out NMEA instead of whatever the default is? Example: My Garmin by default is NOT NMEA, it is a Garmin protocal. so it only works with my Garmin Map Source CD's I purchased.
yuprules is offline   Reply With Quote
Old 02-26-2004, 10:52 AM   #5
ukchris's Avatar
ukchris is on a distinguished road
What do the strings look like in HyperTerminal?
I've found MapPoint to be fairly picky, it likes a very good lock before it is happy to show position. Did your GPS come with any test program? Mine (Deluo) has a test app, I guess it should be generic, you might want to grab it from their web site and try it.
You did close down HyperTerminal I assume... apps don't like to share serial data.
Chris.
ukchris is offline   Reply With Quote
Need good GPS software for Canada Bobby Digital GPS 7 02-11-2004 07:45 PM
Navtech maps for Canada greenglo GPS 2 02-04-2004 11:29 AM
Map Point Striker169 GPS 26 10-29-2003 12:01 PM
