Quote: Originally Posted by Pebben
Back again, when i click on Destinator i get the following message: "Run-time error '13'. Type missmatch"
I can't remember ever seeing that...
Can you try uninstalling both the Destinator SDK, and MediaCar, and trying both again
When you install the SDK, make sure you run the "InstallPC.exe" provided. You should then in the C:\PowerLOC\Destinator\ directory get Destinator.exe and DestinatorDaemon.exe
When you set up MediaCar, do not put in a file name for the External GPS
It isn't needed, and may only confuse the matter
Garry
