Old 03-27-2004, 11:42 AM   #16
eCar™'s Avatar
Quote: Originally Posted by Maeveth
Which Garmin do you have?
eTrex Vista. It's a handheld.
eCar™ is offline   Reply With Quote
Old 03-27-2004, 01:05 PM   #17
Ah I see, well can anybody recommend any more units? One person gave a link but it shoots me to ebay and I really dont like ebay.
2003 Subaru Impreza TS
Staus: Done.. too lazy to make pictures lol.
Maeveth is offline   Reply With Quote
Old 03-27-2004, 01:22 PM   #18
I found this one
http://www.gpscity.com/gps/brados/21.../OEM16LVS.html
But it has a RJ-45 connector on the end, any idea how to wire it up so it can hook into a PC? The below link is the manual too it and it talks about doing it but im not sure how easy it would be to do it
http://www.garmin.com/manuals/68_QuickStartGuide.pdf
Old 03-27-2004, 02:06 PM   #19
MP3DUB's Avatar
Its been a long time, but I know there are guides out there for wiring up a garmin 16 to a standard serial port, as it was what i was going to use before I ended up buying the deloreme.
-Nick
_____________________________
Monthly MP3Car Chicago Meets
www.mp3vw.com Last updated: 07/07/2008
MP3DUB is offline   Reply With Quote
Old 03-27-2004, 02:40 PM   #20
What you guys think about this?
http://www.navtechgps.com/supply/gps16.asp
Old 03-27-2004, 06:47 PM   #21
wi77iam's Avatar
Too expen$ive.
wi77iam is offline   Reply With Quote
Old 03-27-2004, 06:58 PM   #22
Other than price... functionality?
Old 03-28-2004, 01:29 AM   #23
I've had a GPS-16 for about a year and it works fine although it isn't the smallest unit on the market. You can either make an adapter cable with an RJ-45 jack and a 9-pin connector on the other end or cut the RJ-45 connector off and put your own 9-pin connector on. Either way, you need to have a "Y" in the cable to provide the 12VDC required. I'd put a fuse in the 12V line too. Instead of a cable, I put two connectors in a small box with a fuse holder and a power switch and connector. Then I just use a standard 9-pin RS-232 cable to connect the computer to the box. The power connector matches one of the "brick" power supplies I had laying around. I can use it to power the GPS if I want to hook it up to the computer in the house for testing or whatever. The manual will have the pin-outs, and also has a couple of schematics for suggested hookups.
Alan
Alanh is offline   Reply With Quote
Old 03-28-2004, 02:45 AM   #24
On that Navtech website they show they have a USB converter for it as well. Any idea of this works?
Old 03-31-2004, 01:05 PM   #25
lerandell's Avatar
How about this one? It looks like it would work. WAAS and USB.
Am I reading it correctly, that is says it has 1 to 5 meter accuracy?
Quote:
DGPS (Differential GPS)
Position 1 to 5 m, typical
http://www.gpscity.com/gps/brados/11.../gm210usb.html
Randell Kelly
X-10 Media Remote
2003 Ford F-150 Harley Davidson Edition
SELECT * FROM users WHERE clue > 0;
0 rows returned
lerandell is offline   Reply With Quote
Old 03-31-2004, 01:58 PM   #26
I don't know if this has been posted on this thread already and I apologize if it has. But, here's the current accuracy levels offered by GPS according to Garmin.
100 meters: Accuracy of the original GPS system, which was subject to accuracy degradation under the government-imposed Selective Availability (SA) program.
15 meters: Typical GPS position accuracy without SA.
3-5 meters: Typical differential GPS (DGPS) position accuracy.
< 3 meters: Typical WAAS position accuracy
XMfan is offline   Reply With Quote
Old 03-31-2004, 07:51 PM   #27
Saw that one but its a knock off brand and im going to stick to a brand we all know and love.
Old 04-01-2004, 01:56 AM   #28
studmonk3y's Avatar
I preordered the pc version of this new Garmin unit. It goes for about $85-90. You can buy it from amazon as well as online gps vendors, make sure to get the bare wire or pc version though, the usb only supports garmin data format. http://www.garmin.com/products/gps18/
studmonk3y is offline   Reply With Quote
Street Atlas isn't all that great... any ideas? swellfellaT GPS 42 03-30-2004 06:18 PM
Position updates faster than 1s or GPS with intertial sensor? gork GPS 19 10-03-2003 04:51 PM
For those considering the Garmin GPS35... jshrieve General MP3Car Discussion 19 05-29-2002 04:29 AM
