The EarthMate is not specifically designed for PDAs. It'll work if your software supports the rockwell protocol, but that's rare on PCs and probably even rarer on PDAs. I remember that Solus supported it, but I don't know about CE software. Check the options on your software. If it just says NMEA, you're out of luck with a serial Earthmate. If it says Rockwell somewhere, you're probably in luck.
BTW, the USB Earthmate supports NMEA too, I think.
