Old 04-02-2004, 05:45 PM   #1
dignome is on a distinguished road
Earthmate: USB Interface - linux kernel 2.6.10 or above via cypress_m8 module
The cypress_m8 module started being distributed with linux kernels 2.6.10 and above. The instructions originally here have since forth been deprecated. This is only for people wishing to use the Earthmate with the USB interface. As mentioned here and elsewhere, the device can be connected via a standard rs232 serial interface.
To enable the driver, from menuconfig or xconfig select:
Device Drivers->USB Support->USB Serial Converter support->
<M> USB Cypress M8 USB Serial Driver (as either built in or module)
Compile, install, then reboot. Depending on your distro, the node being created by the driver can show up as /dev/tts/USB0, /dev/ttyUSB0, or /dev/usb/tts/0 (the number will vary). If you have udev, you can configure it to create the node however you like based on the product and vendor ids; VID:0x1163, PID:0x0100. Check with your distro for support on where usbserial nodes can be found and for further information on configuring udev.
For people not using linux or using a kernel less than 2.6.10 or even the 2.4 series, please check out the emul project at:
http://developer.berlios.de/projects/emul
Last edited by dignome; 04-06-2005 at 07:11 AM.. Reason: edited title for clarification, updated information regarding the cypress_m8 module
dignome is offline   Reply With Quote
Old 04-06-2004, 05:41 PM   #2
Super Moderator
hijinks21's Avatar
hijinks21 is on a distinguished road
excellent post. I was just about to sell my earthmate cause it couldn't be used in linux.
i'm bookmarking this post
'98 Explorer Sport
80% done
hijinks21 is offline   Reply With Quote
Old 04-02-2005, 03:32 PM   #3
FYI, anyone still wishing to use their usb earthmate with gpsd should check this out:
I'm trying to make it as platform independent as possible. The dependcies include:
libusb>=0.1.8
pthread support
Old 04-02-2005, 03:54 PM   #4
Raw Wave
rando's Avatar
rando is on a distinguished road
As stated above, the USB Earthmate has a serial ouput and Cypress converter to provide USB support. What's less known is that the internal serial interface is directly available at the connector allowing the USB to be bypassed completely. All you have to do is solder a few wires to the supplied USB cable to convert it into a serial cable. Search the forums for the details. The output is standard NMEA over serial@4800,8,n,1. It should work with ANY NMEA compliant software on ANY OS.
2004 4runner
rando is offline   Reply With Quote
Old 04-05-2005, 11:44 AM   #5
SnyperBob's Avatar
SnyperBob is on a distinguished road
hey guys.....can someone edit the title of this thread to iniclude the word 'Linux' in it? I don't run Linux, but when I get time to try it, this will be very interesting. I think it may help other people trying to search the forums as well.
www.mobile-effects.com
Free file hosting, picture gallery hosting for installs, PM me.
Internet's first Front End Skin browser, featured installs, downloads, links, informative articles - all free to registered users.
SnyperBob is offline   Reply With Quote
Earthmate USB to Serial cable New_Compact GPS 22 05-22-2008 02:55 AM
Help With Earthmate USB to Serial Conversion rgardjr GPS 3 02-03-2004 09:13 PM
Delorme Earthmate USB with CoPilot 2003 JoeMac GPS 17 09-10-2003 05:01 PM
FS: Delorme Earthmate USB + Two 802.11b NICs Kessler Classified Archive 3 08-14-2003 12:47 AM
PalmAmp USB support! Old El Paso General Hardware Discussion 11 01-16-2001 12:25 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
