Old 04-20-2004, 02:00 PM   #1
pip
pip's Avatar
Cool Plastic cars are transparent for GPS
I'm in the process of getting the components together for my carputer. I was wondering how to mount the GPS when I realized the body panels on the car are plastic. I simply velcrod my eathmate inside a horizontal panel and it sees the gps birds right through the body of the car. Cool!
pip is offline   Reply With Quote
Advertisement Sponsored links
Old 04-20-2004, 02:13 PM   #2
What kind of car do you have?
Never be afraid to do something yourself. Remember - amateur built the Ark, professionals built the Titanic.
arkadiyp is offline   Reply With Quote
Old 04-20-2004, 03:17 PM   #3
prolly a saturn
mp3mike05 is offline   Reply With Quote
Old 04-20-2004, 03:21 PM   #4
Raw Wave
Confused's Avatar
Yep.
Metal and concrete are the only things that really block the signal greatly (well, enough so that you don't get a decent fix)
Co-Developer of A.I.M.E.E
www.aimee.cc
Confused is offline   Reply With Quote
Old 04-20-2004, 04:47 PM   #5
frenchnew's Avatar
There is a metal skelleton on a Saturn underneath the plastic shell.
regards
frenchnew
frenchnew is offline   Reply With Quote
Old 04-20-2004, 04:59 PM   #6
pip
pip's Avatar
I have a C5 Corvette.
Old 04-20-2004, 05:01 PM   #7
Sway's Avatar
wanna cookie?
Sway is offline   Reply With Quote
Old 04-21-2004, 11:06 PM   #8
Quote: Originally Posted by Sway
wanna cookie?
wanna be a dick?
mp4runner.com
saletel is offline   Reply With Quote
Old 04-25-2004, 12:22 AM   #9
The only corvettes out there with platic body panels are going to be 1/24 scale and sold by a company like matel and will require painting, glue, and assembly. Someone can correct me if im wrong, but dont all corvettes have fiberglass bodys?
david_594 is offline   Reply With Quote
Old 04-25-2004, 12:37 AM   #10
aleromaster's Avatar
new ones are composite. I should know I sell them. Unless yu want a zo6 comremetive edition then it has a carbon fibre hood and composite panels
2002 Oldsmobile Alero GL2 4DR
Aleroputer 90% done (ripped out and being rewired)
MYMODS:
Pioneer Head unit in a remote location, Clarion Amp, XM Satilite Radio, 2 10" Audiobahn DVD Subs wired 1 ohm in a bandpass box, Grill Mesh, Halo Guages
aleromaster is offline   Reply With Quote
Old 04-25-2004, 02:09 AM   #11
emf
The C5s are close enough to tupperware . . . . it's less fiberglass than plastic depending on the panel that you're talking about.
pip -- Where'd you end up doing the install in your C5 -- I'd be interested in comparing vs what I stuck in my Z06.
emf is offline   Reply With Quote
Old 04-25-2004, 11:10 AM   #12
pip
pip's Avatar
The carputer is actually still on the bench
However I'm planning to put the carputer in the center trunk storage compartment. Theres plenty of room in there for the computer, USB doodads and room left over for some amps when I replace the bose with 5.1 surround sound
I'm planning on replacing the lid of that compartment with a clear panel with led fans and one of those funky electro static blue lights.
The cable for the gps puck runs behind the back panels to the horizontal surface under the body panel to the side of the trunk lid. Its velcro'd in place there.
Old 04-25-2004, 11:13 AM   #13
john1701's Avatar
my gps is on the dash. Since I have a real steel car.
CAR:2001 Ford Crown Victoria
PC: HP 530 NoteBook with Vista with Centrafuse 2.0
Memory:2G
Drives:80gig
WI-FI:Cingular
GPS:IG 4
Screen:Xenarc 700TSV
The Florida Meets Thread
Simple Fix to Road Runner and Vista
john1701 is offline   Reply With Quote
Old 04-25-2004, 11:18 AM   #14
emf
If I might make a recommendation
There's a proverbial crapload of space under the passenger side of the dash for USB gadgets and the like. Similarly, since the accessory power connector is right in the passenger footwell, it's a piece of cake to fab a new passenger-side footwell panel, and stick everything up front -- you do need to build up the footwell panel by about 1" - 1 1/2", but I've found that most people don't even notice. It beats having to worry about the heat in that center pocket, and still keeps a significant amount of space available for subs [unless you fab into the side pockets] and general storage.
GPS receiver then can either go in the dash behind the center AC vents, on the side next to the passenger a-pillar, or on top of the tunnel.
'02 Z06 -- 439RWHP / 408RWTQ
EPIA M10000, Xenarc 700TSV, Opus 150w PS, 120GB WD HDD, LS1 Edit and EASE, custom telemetry and datalogging
'03 Excursion -- 372RWHP / 520RWTQ
EPIA M10000, PW70A, 200GB WD HDD, Kenwood 911DVD
Old 04-25-2004, 12:30 PM   #15
my hole trunk lid is plastic.. ill have to try it
beaverpants is offline   Reply With Quote
drilling through plastic jusatry Fabrication 28 01-14-2007 12:22 PM
Transparent Backcolor components?? SonicCobra03 Software & Software Development 9 02-17-2004 01:06 PM
depressing old cars... mp3z24 Off Topic 3 09-09-2003 05:41 PM
A dearth of good entry American cars? MP3DUB Off Topic 5 02-27-2003 11:41 AM
