Old 05-20-2004, 02:07 PM   #1
Capture GPS data at the flip of a switch
Hello,
I have a need for gathering GPS data based on switch activity. A truck driver will flip one or more of several switches on a dashboard. When a switch(or switches) is(are) flipped, I need to record a waypoint at the position the vehicle is when switch activity occurs. As well, I would need to record which switch was flipped. For example, if switch A is on and I flip switch C on and turn switch A off, data log "GPS waypoint, switch C on, switch A off". Or if switch B is on, and I flip switch A on without flipping switch B off, data log "GPS waypoint, switch A on". Then if I flip both switch A and B off and flip switch C on, data log "GPS waypoint, switch A off, switch B off, switch C on". Of course there are many different scenarios but the simplest view is to data log "GPS waypoint, switch, off/on" no matter what scenario occurs.
Hopefully this gives a clear picture of what I'm after.
Any help would be greatly appreciated as I have tried researching this for a solution and have come up empty after several days of effort.
Thanks,
Mr. I
p.s. Note that I am open-ended on the hardware/software configuration. I can go with a GPS-enabled PDA (such as a Garmin product) or a GPS receiver connected to a laptop, or any other similar configuration. If data capture can flow through a data logger then good; if needed to be parsed out and reconciled via software program on laptop then that's ok too. Final results will be plotted in ArcView(most likely) or equivalent.
Mr. Inquisitive is offline   Reply With Quote
Old 05-20-2004, 02:58 PM   #2
my ngpsd gps daemon for linux should be able to do that...
check my site at http://www.navsys.org and send me some mail
I don't need no stinkin' startup-shutdown controller... That's what journalized filesystems are for...
NavSys, the ultimate navigation app
http://www.navsys.org/
sxpert is offline   Reply With Quote
Old 05-20-2004, 06:05 PM   #3
Raw Wave
Laidback's Avatar
3 switches for a truck driver!! Aren't you going to confuse him??
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 05-25-2004, 10:38 AM   #4
Talking
Not only confuse him but might make him spill his coffee or drop his donut while trying to flip the switch
Poor truck drivers ..... they get such a bad rap hehehe
Old 02-02-2005, 07:06 PM   #5
crazymadbastard's Avatar
hey don't underestimate the drivers those rigs can have 10 + gears.
I have trouble sometimes with my 6 foward gears...
Iwill ZPCgx 2.4ghz cel, 256mb pc2700, external combo drive, 80gb 2.5 laptop drive, xp pro, usb gps, 7 in Lilliput TS , carnetix CNX1900. All mounted ghetto- still experimenting and tweaking.
crazymadbastard is offline   Reply With Quote
VOICES Traffic Data stevieg V.O.I.C.E.S 85 05-31-2004 09:24 PM
Need clairification on wiring on/off switch syclone477 Newbie 9 03-23-2004 05:59 PM
Help decoding some GPS data stevieg GPS 4 03-14-2004 04:48 PM
Using a microprocessor to display GPS data on an LCD Zip-Lock GPS 15 10-21-2002 04:06 PM
winamp plugin -> gps data on char lcd ShinkunoNamida GPS 12 09-29-2002 10:19 AM
