Old 05-25-2004, 06:42 PM   #1
jhu
jhu is on a distinguished road
Deluo GPS and Navigon incompatibility?
I just hooked my Deluo USB GPS on my laptop to use it with Navigon MobileNavigator for the first time and a very strange thing is happening.
Netstumbler and Alturiion GPS both "see" the GPS signal, but the Navigon says there is no signal attached. I've switched Com ports, but the problem remains.
Is there a possible problem between the Deluo GPS and the software?
jhu is offline   Reply With Quote
Old 05-25-2004, 07:16 PM   #2
Raw Wave
wizardPC's Avatar
wizardPC will become famous soon enough
make sure all the settings are correct. the deluo unit is an NMEA reciever, so any program that uses NMEA will work.
Debt as of 1/1/05: $34,354.48
Debt as of July 4, 2007: $0.00 explanation
Total spent on wedding so far: $3885.79
Thanks to everyone for your support.
I'M DEBT FREE!!
wizardPC is offline   Reply With Quote
Old 08-26-2004, 05:07 AM   #3
BeamRider's Avatar
BeamRider is on a distinguished road
It's Navigon default configuration....you've to change the SPGPS.ini
If you still need help on it leave me a PM .
Installation: 90% complete - fiberglassing
EPIA M10000 - 512Mb - 20GB
Lilliput 7" TS - Opus 150W PCB - DLink USB Radio - slim CD-ROM - SoundBlaster MP3+ - not so crappy 40x4 Amp - BU303 GPS (waiting for) - BT support
BeamRider is offline   Reply With Quote
Old 08-30-2004, 05:15 PM   #4
djkriz is on a distinguished road
Mobile navigator only needs the NMEA GGA and VTG output sentences.
Program your gps device to send only those 2 sentences, and it should work.
I used u-center to set it up, but you can also use sirfdemo.
djkriz is offline   Reply With Quote
GPS Software for X86 PC and 7" Touchscreen segerdahl GPS 7 09-05-2005 12:50 PM
