05-25-2004, 07:05 PM
#1
Linux Gps/Navigation solution?
I'm looking for some gps/navigation software to run on my Xbox w/ Gentoox installed. any ideas? i have have a usb port modded to the xbox so i shouldn't have a problem using the little gps antenna thingy as long as i get drivers for it.
features i'm looking for:
turn by turn
dynamic routes (incase a mistake is made, it will recalculate the route)
and thats it in terms of required features.
i've searched the forum for this info, but most of it was posted over a few months ago so i'm sure there is new software and new opinions on that software. thanks for any input!
05-25-2004, 07:17 PM
#2
n00b 4 life
Where are you? If you are in europe then Infomap Navigator will do that and comes with both Windows and Linux versions on one disk for £35...
New Car
New Car computer will follow........
(Gazes at pile of components)
05-25-2004, 07:27 PM
#3
Personally I have not seen anything comparable to windows apps for linux  If you find anything that has North America maps an SDK and is comparable to Routis, Mappoint, Copilot Live or Destinator please let us know.
Migrane
05-25-2004, 07:58 PM
#4
You may want to try www.dashpc.com's forums too. They are a linux based car pc place.
05-25-2004, 07:59 PM
#5
The only linux based GPS software I've seen is GPSdrive http://www.kraftvoll.at/software/
1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
05-25-2004, 11:57 PM
#6
i live in the US, virginia actually.
hmm, maybe i should go ahead and load xp, hmm, gps/navigation is my main reason for having a carpc. too bad i can't use my xbox though... thanks for the input guys!
05-26-2004, 12:31 AM
#7
Can the Xbox run wine? That might give you a (somewhat messy) solution?
89 Celica, CarPC installed, 1st bday :)
http://www.fishy.net.nz/carpc/- MediaEngine
- Epia V8000
- 80GB WD 7200RPM HD
- Xenarc 700TS
- SB Live
- Opus 90W
- CIMR100 remote
- Deluo serial GPS
- D-Link USB radio wired to power antenna
05-26-2004, 03:14 AM
#8
If you live in the U.S., check out sumit's TMRS software. It uses the free Tiger map database to return a map from GPS coordinates and plan out routes. That combined with gpsd (which actually talks to your GPS hardware and give you your current position) should get you well on your way.
1994 RX-7, EPIA P4-ITX w/ Celeron 2.4 Ghz, Arise PSU, Xenarc 700TSV (new model)
05-28-2004, 06:59 AM
#9
Registered User
Anyone used the linux version of Navigator? might be exactley what I've been waiting for to consider ditching windows.
4x4 in a turbo stylee.
05-29-2004, 07:45 PM
#10
Aultl
[====---] - 65% complete
Status: Configuring Software
VIA Epia 800mhz, 256Mb ram, 10Gb HD
Quote of the Month: "I see the problem, [The RAID controller] is trying to rebuild the array with good data from a failed drive." -- HP Support
| Thread Tools |
| Display Modes |
Linear Mode
