Old 05-26-2004, 12:56 PM   #1
kiztope's Avatar
How do I set this up! (Destinator)
I got a GPS mouse off of ebay, and d/l Destinator off of the Hub.... How in the heck do I set it up? Every time I open the installer, it says that there are no mobile devices connected. How do I install this onto a PC??
Thanks!
kiztope is offline   Reply With Quote
Old 05-26-2004, 01:07 PM   #2
Confusion Master
Enforcer's Avatar
have you installed the software with the mouse. It should give you a vitual com port.
then you need to tell Destinator which port that is.
Enforcer is offline   Reply With Quote
Old 05-26-2004, 01:26 PM   #3
Raw Wave
Laidback's Avatar
Thanks!
You're trying to run the installer for a ppc, you need the pc version.
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 05-26-2004, 01:50 PM   #4
kiztope's Avatar
So, will getting the SDK fix the problem?
Old 05-26-2004, 02:11 PM   #5
Confusion Master
Enforcer's Avatar
yes.
Oh and you will need the D2 maps from the PDA version
Old 05-26-2004, 02:46 PM   #6
kiztope's Avatar
I am now away from my home PC, and at work.
What do I need to do when I get home to get it to work?
I am havent done any programming in years, and have no idea what to do with SDK's.
Are there instructions in the zip file?
Old 05-26-2004, 03:12 PM   #7
I got the rhythm.
Danceheaven's Avatar
if i remember correctly its been a while you install the sdk it then creates a dir called powerloc and then a sub dir called destinator, you then copy the maps (what ever country you are using) to the maps folder then run the exe
something along those lines.
Co Develper of A.I.M.E.E Automotive Intelligent Multimedia Entertainment Engine
www.aimee.cc
Danceheaven is offline   Reply With Quote
Old 05-26-2004, 07:34 PM   #8
kiztope's Avatar
Anyone concur?
Old 05-26-2004, 08:18 PM   #9
00CericaRuss's Avatar
i concur, but i havent' fully tested the functionality of the sdk
Car: 2000 Toyota Celica GT-S
Mods: Yep
Carputer: VIA M9000 | Opus 150 | 512MB PC2100 | 60GB Notebook HD | Slim/Slot DVD/CDRW | Audigy2NX | Xenarc 700TSV | (2) DSCustoms DS700HRS (in trunk) | SMC USB 802.11b | CoPilot | DLink FM tuner | Cliffnet
00CericaRuss is offline   Reply With Quote
Old 05-26-2004, 09:45 PM   #10
kiztope's Avatar
so, where are the maps?
Old 05-27-2004, 02:11 AM   #11
kiztope's Avatar
okay, I figured the maps out...
Thanks for the help! Im going to test it all out on the laptop tomorrow morning..!!
Old 05-28-2004, 06:49 AM   #12
Noctris's Avatar
Hmm
I've been playing with the SDK today and have a question though
Ok, so I've got the maps working but when I have to switch map do i seriously have to figure out which map I need ( E1, E2, E3, or G1A for germany ?)
I need to unpack the maps to c:\powerloc\destinator\[nameofmap] ?
Isn't there a way that I can simply unpack to c:\powerloc\destinator\germany\[PARTX] and it automatically knows what map it needs ? this is kind of a hassle or am I missing something here ? I'm pretty luck to live in belgium as such a small country is fit into 1 map ;-). .but in germany I don't feel like going 180 on the Autobahn and then needing to switch maps with a lucky guess if I now need G1A or G6b ?
I'm going to hell, who's comin' with me ?
Renault LagunaII 1.9 CDI
Carputer Install Progress: [*********-] 90% - Cleaning up
VIA-MII10000 - 512MB Ram - 80Gb HD - Lilliput - GPS - OPUS 150Watt
Noctris is offline   Reply With Quote
Old 07-24-2004, 12:19 PM   #13
Big wave for this excellent short instruction :-D - just remember that it seems that you have to at least install one map in order for getting it to work, and the maps you copy over has to be in their own folder, otherwise the program keeps on crashing or at least that is my experience when using the D3 maps, now it will stand a true roadtest next weekend when running down to a car meet around 550 miles south of me, and then cross Denmark to visit my mom, a journey of a total in the end around 2000 miles, if it can guide me correct here it will be applied to my carPC otherwise AutoRoute from Ms is going to win the contest.
[lll------------]
Have:
MSI KT3-Ultra MB
10/100 3com NIC
ASUS ATI RADEON 9200SE TV-OUT 128MB
Bluetooth/Nokia 6600/GPRS
Need:
Opus 150 PS
XP 2200 CPU
PC2700 256MB RAM
MSI DVD-Writer DR8-A2
Barracuda 7200.7 80GB HD
SB Audigy 2 PCI
WhiteWolf_DK is offline   Reply With Quote
Destinator 3 SDK availability schedule information Confused Software & Software Development 37 08-26-2004 06:57 PM
Destinator with Speed/Bearing, and Winamp control Confused MediaCar 136 07-11-2004 02:08 PM
Updated Destinator: with Speed/Bearing, Winamp control and Speed Camera Database Confused MediaCar 11 04-12-2004 06:10 AM
Destinator crashes MediaCar Laidback MediaCar 0 04-04-2004 04:05 PM
Destinator PocketPC Maps with Destinator PC SDK bypo GPS 5 09-09-2003 09:01 PM
