Old 06-25-2004, 05:11 AM   #16
MoFo's Avatar
Quote: Originally Posted by MatrixPC
Holly $hit, it works. Thanks Mofo. Well I haven't try on my carPC yet, but it works on my desktop and it lock into 7 sats very fast and I am indoor. Well the receiver is on the window.
From MoFo instruction above, after installed the driver from Delorme, you have to restart the PC as requested by the installation software. That the only thing MoFo left out. COOLLLLLL.
[edit] Before follow MoFo instruction, I did try to install on my desktop but the PC keep reboot when selecting the COM port. The driver is the one I download couple weeks ago. I am not sure it is the same driver I down load today or not. So that is the different for me. [/edit]
I'm glad it worked for you MatrixPC. I know how frustrating that blue screen was.
MoFo is offline   Reply With Quote
Old 06-25-2004, 08:08 AM   #17
TaylorMade's Avatar
Yeah, Matrix, I'm up and running. I used it today as a matter of fact. I'm sure you were just asking me that because you were still having problems, but I figured I'd answer ya anyway.
Denali XL
Carputer yanked from the Jeep and installed in the Denali...pics coming!
Check the old one here
TaylorMade is offline   Reply With Quote
Old 06-25-2004, 11:40 PM   #18
thankyou thank you thankyou thankyou, was just aboput to bid on another gps mouse but figueres id check the boards first...thank you soo so much
junior757 is offline   Reply With Quote
Old 06-26-2004, 12:58 AM   #19
MySQL Error
MatrixPC's Avatar
Ok I have some problem with hibernation again.
If I have the GPS plugin along with USB wifi card, usb memory card reader, or usb HD, the computer will hibernate. But when restart from hibernation, none of those USB devices work including the GPS.
If the GPS is NOT plug in when I put the system to hibernate, all those USB devices work as normal when restart from hibernation.
unplug and replug the GPS or any other USB devices doesn't do much. Basically all usb devices for the system are disappear.
Any idea?
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 06-29-2004, 09:08 PM   #20
btw, where do you guys place your earthmate usb gps? trunk?
gaphix.com
MSI KM4M MicroATX, Duron 1.6, 512 Micron 2700, WD 80 7200 8mb, Pioneer 120S, M-audio 7.1 pci, Targus USB 2.0 hub, 3com 11a/b/g pci, PNY FX5200 AGP 64mb, Lilliput 7"
hifiguy is offline   Reply With Quote
Old 06-29-2004, 09:23 PM   #21
MoFo's Avatar
I'm pretty sure it wont work in the trunk.
I have mine on the rear deck but I would like to weatherproof it and put it outside the car like Veetid did in this thread: http://www.mp3car.com/vbulletin/gps/28219-earthmate-not-weatherproof-need-help.html.
Old 06-30-2004, 02:17 AM   #22
MySQL Error
MatrixPC's Avatar
I have sometime today to try the new driver on my carpc and it work wonder. However the hibernation is still a problem. The GPS work fine after hibernation but USB WiFi is not working and so the USB Keyboard and memory card reader.
If the comptuter is going to hibernate while Routis is running, when come back, Routis doesn't get any GPS signal (maybe I am not waiting long enought). Close routis and re-open, GPS signal will come in like within 5 second. Getting the GPS to lock is depend on where the receiver is. If I put on the daskboard, it will lock to sat within 10 second after Routis is on. Right now I have the receiver in the glove compartment and it can lock up to 5 or 6 sat within a min or 90 secs. So at least I don't have to use any COM port forwarding stuff.
Thanks Curiosity for a great Xport program. Although I am not using it now but I know I will use it sometime in the future. GPS stuff is getting addictive
Thanks MoFo for the instructions for this new driver and Wi77iam for the port forwarding idea.
