Old 06-04-2004, 12:37 AM   #1
Mac Car Moderator
kandyman676's Avatar
kandyman676 is on a distinguished road
Help with drivers for USB Earthmate?
I am running Windows XP Pro, and for some reason the USB Earthmate will not recognize..period. When plugging in, it detects it as a USB unrecognizable device, and the device blinks 3 times red. It is directly connected to the laptop (Dell Latitude CPx)
I have tried to do the USB to Serial driver also, but no luck either. Also tried to search delorme, but nothing there of any help. Any ideas what to do?
Its driving me nuts that it is not detecting!
"If it works this good why F with it?" -KMFDM "Intro"
Strive for ethical wardriving: http://faq.wardrive.net/
My CarCPUs: v1 - 2000 | v2 - 2004
Mp3Car Meets: http://detrimental.org/eyecandy/MP3CarMeets
kandyman676 is offline   Reply With Quote
Old 06-04-2004, 01:15 AM   #2
dignome is on a distinguished road
This same issue has happened to me. First you need to download and extract the drivers from DeLorme's website here:
http://www.delorme.com/support/gps/uemate005.asp
Extract the files into some directory.. (IE: c:\EMateSetup)
Next open up the Device Manager, you can quickly go to this by launching "devmgmt.msc" from Start->Run.
When you plug the earthmate in it should show up in Windows Device Manager under Human Interface Devices. It will probably be listed as "USB Human Interface Device", if you have a mouse or other HID devices they will also show up as this... right click on the first device with the previously listed name "USB Human Interface Device" and then go to update driver. Next choose "Install from a list or specific location (Advanced)" and click next. Check the radio button "Search for the best driver in these locations" and also check "Include this location in the search:"... now enter in the directory where you extracted DeLorme's usb2serial driver then click next. (IE: C:\EMATESETUP)
If the first listed device is not the Earthmate, the above process will yield nothing, try the above with the next listed HID device. When it successfully finds the Earthmate, say yes to the dialog asking you if you are sure you want to install an unsigned driver. You may or may not get this.
Finally... you may have to restart to see if it worked or not, it should be visible and configurable in the device manager under "Ports (COM & LPT)".
I hope that helps.
dignome is offline   Reply With Quote
Old 06-04-2004, 08:44 PM   #3
Mac Car Moderator
actually, i ended up taking the device back. it would not autodetect even as a HID! i exchanged it with another, bringing my laptop along to make sure it worked:-P
also, there was only one thing off with your directions...instead of doing the search, do the "Don't search" option, browse to the driver, then install. I was trying the search, pointing to the path, and it would not do jack ****. I also found these directions when poking around on the manufacturer's website:
http://www.delorme.com/support/gps/uemate003.asp
Thanks for the help though:-)
TouchScreen Drivers & Installation [iG] Input Devices 15 02-17-2005 11:40 PM
Linux drivers for Lilliput Touchscreen? Visual Echo LCD/Display 18 11-07-2004 08:05 AM
Lilliput drivers do not install with bluetooth ryguy LCD/Display 4 06-12-2004 11:52 AM
Earthmate only locks when GPS Software is running nodeel GPS 5 01-04-2004 10:43 PM
Touch screen drivers freezes my computer cooljavy Input Devices 5 06-15-2003 08:35 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
