Old 06-14-2004, 09:44 AM   #16
Quote: Originally Posted by Goto10
I might have a sniff at the data going to the B2 from the update program, if it's parsed/uncrypted before it's sent to the B2 then it should be easy to extract, if it's parsed within the B2 then it'd be a massive challenge to extract/uncrypt it!
I had a quick sneak into the RoadAngel's update program and it appears to retrieve it's data in a simple XML format. Unfortunately I don't own a RoadAngel and am not the sort of person to "test" their software to see how it works!
If somebody with a RoadAngel could run an update while logging the HTTP traffic using Ethereal it would be most useful:
http://www.ethereal.com/download.html
Gareth
g_attrill is offline   Reply With Quote
Old 06-14-2004, 03:13 PM   #17
Map Monkey Creator
Ninja Monkey's Avatar
I have a snooper S4, using ethereal I managed to intercept the latest file while it was being updated.
It makes no sense to me but I'm sure someone can work it out and format it correctly.
http://homepage.ntlworld.com/shaunjo...ationsLite.txt
Ninja Monkey is offline   Reply With Quote
Old 06-14-2004, 04:19 PM   #18
Goto10's Avatar
Hehehe quality - that can be manipulated fairly easily, I'll have to check B2 downloads as I have a subscription for my B2 unit anyway, so can then play around with the data - could then update the speed camera software to have directional data, speed limits etc etc and using very accurate data
I've done some updates to current one, calculations run a lot faster now and consume far less CPU time, plus a smaller 'footprint' on screen. I'll put it up for download in a bit if anyone wants it (ver 0.9b)
Speed camera detector for Windows, can work alongside any other GPS application(s);
EvetS page
Goto10 is offline   Reply With Quote
Old 06-14-2004, 04:29 PM   #19
Map Monkey Creator
My snooper tells me the speed limit when i'm approaching a camera, it also won't alert me if it's on the other side of the road...so all that info must be in that file somewhere
Hehehe quality - that can be manipulated fairly easily, I'll have to check B2 downloads as I have a subscription for my unit anyway - would have directional data, speed limits the works and A1 data
Old 06-14-2004, 04:36 PM   #20
Goto10's Avatar
It sure is, what I mean is that it'll be better for me to develop it based on B2 data, because I can get the updates myself that way... (As I have a B2 subscription and not the Snooper)
EvetS page
Old 06-14-2004, 05:16 PM   #21
pottillo's Avatar
Program give me run time error 13 whaen i hit start after loaded database and connected gps.
pottillo is offline   Reply With Quote
Old 06-14-2004, 05:55 PM   #22
Goto10's Avatar
Thanks, I think I know what that is, corrected in next version.
EvetS page
Old 06-14-2004, 06:01 PM   #23
Map Monkey Creator
What I really like about the snooper are the voice alerts telling you the speed limit / distance etc... Perhaps you could use the MS text-to-speech engine to incorporate this?
or even better - have the the option for the app to constantly output all the details to a file so we can write our own apps to deal with it (For example I'd want to have it mute winamp while it was talking)
It'd be great if I could replace all the functions of my snooper completely :-)
Old 06-14-2004, 06:20 PM   #24
See me in my wet t-shirt.
stevieg's Avatar
Gareth
Done this a while ago using HTTPLook and spent a few hours sitting down doing radian/decimal calculators on the data converted from hex to no avail - feel free to give it ago.
Ford Focus MP3 : www.stevieg.org/carpc
Car PC Status: COMPLETE
stevieg is offline   Reply With Quote
Old 06-15-2004, 04:46 AM   #25
Goto10's Avatar
Yeah, could hook up TTS easily for real time speech.
Writing to a file and another app reading said file, both in 'realtime' would be very messy - I could offer an IP connection? eg 'host' it on a localhost port(127.0.0.1:9999) and output keywords - that would be a much neater way of making it work with your apps (your app would simply connect via a winsock control and listen for events)
EvetS page
Old 06-15-2004, 09:45 AM   #26
Goto10's Avatar
Revised
Ok - the 2nd revision is ready for download (0.95) - now includes various options (minimise to tray, start on load, port config save etc) a much improved calculation routine (less CPU load and faster running) and the ability to connect to it with your own application. (VB or otherwise, uses IP so is fairly universal)
VB demo code for how to connect to the application is at the bottom of the page.
Haven't tested it fully 'on the road' yet so there are bound to be a few bugs!
Next revision will include any bug fixes found here - speed display along with estimated time to camera (including time alerts, so can set it to trigger voice when 10 seconds away, rather than just distance option)
EvetS page
Old 06-15-2004, 10:12 AM   #27
pottillo's Avatar
tested version 0,95. Same run time error n. 13 when i hit start button. If the db is loaded or not or the gps is connected or not, still same error 13. Can this be related to the use of a non english verion of WinXP?
Old 06-15-2004, 10:18 AM   #28
Goto10's Avatar
Hmmm interesting, any other information with the runtime error?
Could you download this one for me and put it in the same folder as the main files you already have - then run debug.exe amd hit 'start' again, and tell me what messages it flags before crashing, will help me pinpoint where it's going wrong.
debug
EvetS page
Old 06-15-2004, 10:34 AM   #29
Wow!
Excellent app, just what I've been waiting for. Cant wait to test it tonight. This will be so cool when driving with friends.
chunkymonkey909 is offline   Reply With Quote
Old 06-15-2004, 10:38 AM   #30
pottillo's Avatar
No messages... when i connect gps it correctly receives gps string, i load db with no errors but when i hit start i receive error 13 and no other message. The onlyu infos i can send are those of ms win error windows (i don't know if it is useful or not):
AppName: debug.exe AppVer: 1.0.0.0 ModName: debug.exe
ModVer: 1.0.0.0 Offset: 00013694
For Sale for all you aussies. Complete mp3 car pc Holden__V8 Classified Archive 20 04-09-2005 06:30 AM
Rand McNally GPS drives my PC WILD... SuperMatty General Hardware Discussion 16 03-27-2003 01:01 AM
Pc rebooting while soft is connecting GPS :( felix99 GPS 5 10-24-2002 12:00 PM
max cpu speed in a book pc model #bki810 Ces///M3 General Hardware Discussion 17 01-27-2002 03:41 AM
gps for a in-car pc? crazyshaxs General Hardware Discussion 2 01-20-2000 09:34 PM
