Old 06-26-2004, 06:52 AM   #46
Goto10's Avatar
Yes, almost there, luckily I've been out and about recently so I've had a chance to test it properly! Options to limit number of beeps etc are now in place, just sorting out the 'jumping' at the moment - mainly just a smoothing algorithm to try and iron out silly GPS inputs - much like the map software does I'd imagine... Hopefully have something ready for next week.
Regarding getting the data from a B2 unit or similar - I've worked out most of what the data means now so might start hosting 'current' data on my webspace for download, includes speed limits, direction of camera etc - that'll be another release away yet though!
Speed camera detector for Windows, can work alongside any other GPS application(s);
EvetS page
Goto10 is offline   Reply With Quote
Old 06-26-2004, 07:13 AM   #47
no1knows's Avatar
good stuff goto, any idea on the shutdown problem?
Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
http://www.no1knows.com/galleries/
no1knows is offline   Reply With Quote
Old 06-29-2004, 05:10 PM   #48
GingerPrince's Avatar
Hi, just had chance to test this software - great work!
Just an idea. Sorry if this has been suggested elsewhere but I've very little time to post/read recently: -
Would be great with a big button that you could press when passing a speed camera it doesn't know about. It adds the camera to the "current" database, and also into a separate file that can be sent to mobilegpswhojermacallits to update their central database. There's about 20 new cameras round me I could add for a start
Also had a problem in that it wouldn't let me hibernate when it was running. Not sure if this was your software or that xport thing will investigate more if I get a chance, but it's imperative that I can hibernate.
Great work tho, keep it up!
GingerPrince
Car changed for TVR Griffith 500, so computer de-installed. Using a Dension 100ix w/60Gb HD unit in the interim.
Carputer Install - http://www.stuffandting.com/carputer/
CarBox Software -- http://www.stuffandting.com/carbox/
GingerPrince is offline   Reply With Quote
Old 06-29-2004, 05:12 PM   #49
Raw Wave
Laidback's Avatar
xport doesn't hibernate yet..
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 06-30-2004, 06:16 AM   #50
nor standby
www.digital-car.co.uk - The UK CarPC Forum
Jamez_Warner is offline   Reply With Quote
Old 06-30-2004, 06:33 AM   #51
Pabs's Avatar
Had a looky at the software, must say looks very impressive. Gotta road test it when i get all my gear
One thing that worries me is the age of the database. If, like in a previous message, you could simply press a button to "ADD NEW CAMERA" as you drive past that would be awesome. Then I can make sure that all cameras in my area etc are mapped for next time!
Otherwise tho, awesome. Keep it up. BTW, I use navigator as well, and if i could get the two working together i would love it!
www.leoncupra.co.uk
Pabs is offline   Reply With Quote
Old 07-02-2004, 09:58 AM   #52
Hi there
Seems like a great program, before DL it and testing it, since I'm living in Sweden and proberly never will drive all the way to England I am wondering - the database in this project, is it possible to replace that with one we make for Sweden? Or how is this imported, will be a great addition to my already excisting setup- at the moment I am running a laptop with Autoroute on it and a GPS module, but main interesst for us here in Sweden is if it is possible to import a special database for us??
Oh, stupid me, just noticed that it mentions something about CSV files on the HP, but am I guessibng right if we who lives in Sweden can start collecting data for the cameras and simply make a text file, save in the CSV format and the program will import that and gives us warnings?
B.R.
WhiteWolf
[lll------------]
Have:
MSI KT3-Ultra MB
10/100 3com NIC
ASUS ATI RADEON 9200SE TV-OUT 128MB
Bluetooth/Nokia 6600/GPRS
Need:
Opus 150 PS
XP 2200 CPU
PC2700 256MB RAM
MSI DVD-Writer DR8-A2
Barracuda 7200.7 80GB HD
SB Audigy 2 PCI
WhiteWolf_DK is offline   Reply With Quote
Old 07-02-2004, 10:29 AM   #53
Great program Goto10!
I wanted to do this myself but it looks like you've already got it sussed. Just a couple of ideas though.
1. I currently use CheckPoint along with TomTom Navigator on my PocketPC. This works great and gives almost zero false readings. The Checkpoint software only warns you if the approaching camera is within a certain angle. (15 degrees I think but can be changed)
2. Checkpoint warns in seconds (based on current speed) rather than metres. Also, it only warns twice - once at 20 secs, and once at 10secs (user configurable) - I find this more than enough. Unfortunately, -- didn't seem accurate enough to reduce the warning to such a close proximity, but I read that you recently changed the algorithym so that could be why...
3. The IP feature is great (I'll want to use this in my software) but it crashes the program on my machine when disconnecting - even with the included vb app.
Great work - can't wait to have it running constantly on my CarPC.
Jamie
jamieo is offline   Reply With Quote
Old 07-02-2004, 10:32 AM   #54
That should work fine. If you download the UK database from the link on
Goto10's site you'll see the format pocketgps use which you can replicate.
Jamie
Old 07-02-2004, 10:46 AM   #55
Jamie
Thanks for the reply,
Great, that actually makes me think I will set up a subsite to my webhotel so we can collect data from England, Nordics and Germany might even other, but for a start this should be enough to see if there is interrest, and simply have people reporting in the cameras by mails, then update the csv-files - people can then just DL the new files and import them, be a lot of work in the begining - will definitly look into this when I get back from my vacation
WhiteWolf
**Update**
Actually I just decided that I will register my subdomain today so I just need to set up pages in the different languages, and then start collecting, sjould be easy to setup during the weekend.
[lll------------]
Have:
MSI KT3-Ultra MB
10/100 3com NIC
Need:
Opus 150 PS
XP 2200 CPU
PC2700 256MB RAM
SB Audigy 2 PCI
Old 07-03-2004, 02:04 PM   #56
Woohoo! Sorry kinda off-topic this, but I just put a deposit down for a TVR Griffith 500!! Gonna have to find a way to get a screen in there, looks like I'll need the speed camera database more than ever :P
GingerPrince
Old 08-20-2004, 09:13 AM   #57
bertybassett's Avatar
Failed to load control 'CommonDialog' frorm Comdlg32.ocx. Your version of COMDLG32.OCX may be outdated. Make sure you are using the version of the control that was provided with your application.
What does this mean?
Travla C134 case with M1-ITX (new firmware)
Nehemiah EPIA M 10000
256mb memory
20GB H/D
eBay GPS unit
Ninja monkey's Desintator 3 client frontend
Frodoplayer
7" lilliput touchscreen
bertybassett is offline   Reply With Quote
Old 08-23-2004, 07:56 AM   #58
Exo
Exo's Avatar
You are probably just missing the Visual Basic 6 Runtime files which are required by every application written in VB such as EvetS.
You can download them from the Microsoft website HERE
Exo is offline   Reply With Quote
Old 08-23-2004, 08:05 AM   #59
Raw Wave
Confused's Avatar
I am currently implementing something into AIMEE which follows the same principles as this software.
It will work with any country that has TomTom Navigator compatible POIs for speed cameras, and will even warn you of the speed of the cameras
It will also work whether you have/use GPS software or not, it will either read from the GPS software or direct from the GPS receiver
I am mentioning this now as Goto10 seems to be AWOL Which is a shame, as this application looks very good, and very promising.
Garry
Co-Developer of A.I.M.E.E
www.aimee.cc
Confused is offline   Reply With Quote
Old 08-23-2004, 08:24 AM   #60
l9nux's Avatar
I've only just noticed this in the forum, and I'll be downloading this after work today! Very excited, so I'll give you my feedback later in the week!
-= I took the red pill =-
l9nux is offline   Reply With Quote
For Sale for all you aussies. Complete mp3 car pc Holden__V8 Classified Archive 20 04-09-2005 06:30 AM
Rand McNally GPS drives my PC WILD... SuperMatty General Hardware Discussion 16 03-27-2003 01:01 AM
Pc rebooting while soft is connecting GPS :( felix99 GPS 5 10-24-2002 12:00 PM
max cpu speed in a book pc model #bki810 Ces///M3 General Hardware Discussion 17 01-27-2002 03:41 AM
gps for a in-car pc? crazyshaxs General Hardware Discussion 2 01-20-2000 09:34 PM
