06-19-2004, 10:05 PM
#1
VENDOR - Centrafuse
Earthmate not weatherproof need help
I originally had my earthmate attached to the top of my Jeep Cherokee Sport 2001... It has been working perfect for over a month aquiring all sats... Well... Last night it rained really hard and I came to discover just how un-weatherproof it really is... I woke up in the morning and started my car and the earthmate was so wet it fryed it.. I unhooked it, shook it, and water poured out.. I was over my 30 days return with Best Buy, but I was able to get them to exchange for a new one.. "Old one just stopped working for some unknown reason"  .... Anyway... Now I am trying to get it to aquire a signal inside the car and I can't.. I have tried everywhere.. Front, Back, Sides... Can anyone help suggest how I can make this thing get a signal inside my car? Has anyone found a good spot in a Cherokee for earthmates? If not how can I waterproof this thing?
I can't get my money back for this thing so I would love to make it work, but if not what are some other GPS mouses that are 100% waterproof and safe for all weather?
06-19-2004, 11:04 PM
#2
Get a reradiating antenna. The cost about 70-100 bucks. I used to run my GPS in my jeep and that's what I used. In fact I still have my reradiator in a drawer somewhere because I no longer have the jeep
2004 Subaru STI
AMS CG65 2.4Ghz P4 w/512MB DDR, 40GB HD
Audigy2 ZS, Xenarc 700TSV, Gyration Media Center
WinXP Pro, ME 2.1, AudioBahn 5100T Amp
AWT10X Sub, JL XR100-CT tweeters
Sony XPlod fronts, Kenwood Excelon rears
06-20-2004, 01:03 AM
#3
I weatherproofed mine by buying some "Plasti-Dip" from Lowes, it's for dipping tool handles in and it makes a permanent coating (or pretty damned close) over anything... I took the rubber pad off the bottom, because the first time i dipped it, it started to "melt" off as it was having a weird reaction with the dip... after taking it off, it was smooth sailing from there... I dipped the earthmate, with the cable attached, into the plasti-dip... pulled it out slowly after submersing it to about 1" up the cable... hung it up for 30 min, and put on another coat. Let it sit overnight, and all was well.. I had a black rubber earthmate, working perfectly  The next day, it rained.... it kept raining on and off for about a week, and it still works flawlessly... i drive it through the car washes too
06-20-2004, 02:18 AM
#4
I'm sorry, and you are....?
Yeah, Plasti-Dip is some cool ****.
[H]4 Life
I'm a lesbian too.
I am for hire!
06-20-2004, 02:25 AM
#5
Raw Wave
It should work on your dash, under the windshield, unless you have some sort of metallic material (tinting, heating element, antenna) on there.
The plastic dipping or other sealent will probably help for a while but it's possible that condensation will still eventually kill it.
06-20-2004, 02:35 AM
#6
VENDOR - Centrafuse
Going to buy some tomorrow and try out.... that stuff seems like it rocks...
06-20-2004, 03:05 AM
#7
VENDOR - Centrafuse
rando: I have tried to get a single inside the car with no luck... Shakes had similiar problems with a cherokee....
http://www.mp3car.com/vbulletin/show...hmate+cherokee
06-20-2004, 11:49 AM
#8
I doubt it... The seal is the tightest I've ever seen...
06-21-2004, 01:58 AM
#9
Raw Wave
Just do a bit of searching on the net about weatherproofing cables and electronics. It appears to be a complex problem. Even if the coating you're talking about is truly weatherproof, you still have to question the junction between the material and the existing USB cable. Unless you dip it deep enough such that the junction is inside the car, there is a chance that water might seep in that junction. Moreover, the orginal usb cable itself is very unlikely to be weather resistent. If any of that cable is exposed to water, you can expect it to (eventually) become flooded (yes the cable itself). If flooding doesn't short out the cable first, the water will run through the inside of the cable and into the connector and into your GPS unit.
These effects could happen soon or may take years. The good news is that your only risking a $60-$100 device.
Another concern with completely sealing the device is heat. Anyone have any heat related issues with their dipped GPS units?
06-21-2004, 01:03 PM
#10
VENDOR - Centrafuse
Well... I dipped my last night.. Letting it dry today... I will then test it out and post a picture... Looks pretty awesome.. and there is no way water will ever get in this thing.... I also dipped down the usb cable all the way into the car, so everything outside is covered with rubber....
06-21-2004, 01:14 PM
#11
Raw Wave
If the rubber material is that good, I guess you could remove the plastic housing before you dip. That should reduce signal degradation a little.
06-22-2004, 01:44 PM
#12
VENDOR - Centrafuse
worked great... I hooked it up today and received 10 sats... It looks like the extra plastic didn't hurt my signal.. I will post a picture after work...
06-29-2004, 03:14 PM
#13
VENDOR - Centrafuse
Here is a pic... Works great....
06-29-2004, 08:12 PM
#14
wow..that looks good. so much better than the original yellow.
thanks for posting a picture
EDIT: can you post a picture of how it looks mounted on your car? or maybe give some details on how you mounted it
06-30-2004, 01:19 AM
#15
The TripNav is waterproof and works great. They are so inexpensive, you can throw it away and get another one if it dies on you.
Bottom line on interior mounted GPS units... poor reception. They work sometimes, but under anything other than ideal circumstances they perform poorly.
Remember the antenna needs a groundplane, so mount the thing on the biggest hunk of steel you car has that faces skyward.
The US DOT mandates that car roofs are steel. Personally I think this was to ensure that everyone has a good groundplane, but there are other theories...
If you want it to blend in and look pretty paint it to match. If you have a roof rack then you can mount it discretely without much problem...
Goodluck, hope it works out well... The rubberizing looks awsome! I want to rubberize my whole car!
.//Daren
(Epia M10000/C134) (C137/MII 10000) Liliput /Opus 150W/DVD/512MB/80GB/Hummer H1
MediaCar/CoPilot7/Routis
| Thread Tools |
| Display Modes |
Linear Mode
