Old 06-22-2004, 07:13 PM   #1
dubwise
Hacking GPS: External Antenna?
I've got a Deluo USB style GPS (with built-in antenna). Since the case doesnt seem like it is going to withstand the elements for very long, I was wondering if anyone has soldiered an external GPS antenna to the GPS module.
Last time on was on the deluo site I could have sworn they had a model with an external antenna, but now I visit it and it seems to have disappeared. Anyways, has anyone attempted this?
dubwise is offline   Reply With Quote
Old 06-22-2004, 07:29 PM   #2
666
666 is on a distinguished road
open it up
Mitspro
666 is offline   Reply With Quote
Old 06-22-2004, 08:00 PM   #3
Clover
Grayscale's Avatar
Grayscale is on a distinguished road
mine has a solder point where i could easily add an external...but my question is...could it just be a long wire? or does it need to be of a certain length, wavelength, blah blah etc
CarPC install is starting to come along again...
Grayscale is offline   Reply With Quote
Old 06-22-2004, 08:23 PM   #4
Pokey's Avatar
Pokey is on a distinguished road
Solder something on it and let us know....
In reality, nothing should happen to a reciever when an unballanced attenna is used, its only damaging on a transmitter, where the power has to be radiated.
Pokey is offline   Reply With Quote
Old 06-22-2004, 08:40 PM   #5
b_nom's Avatar
b_nom is on a distinguished road
I've got this Trimble GPS Antenna, it's a P/n 28367-00, I found something similar on Trimble's website, and supposeddly it's a 35dB gain 5v antenna . But I'm not able to test it with my Deluo mouse , since my brother has it in his car and is not coming back to Houston till the end of summer
me--> <--my brother
'96 Chevy Cavalier - EPIA M10000, Win2K,MediaCar, Deluo GPS Mouse with Routis, 60GB external HD, 7" widescreen monitor from DigitalWW.
'00 Jeep Wrangler - planning stage
What can BROWN do for you?
b_nom is offline   Reply With Quote
Old 06-22-2004, 10:13 PM   #6
b_nom's Avatar
Thumbs up
I found this on deluo's website. what do ya'll think?
Old 06-23-2004, 09:39 AM   #7
Clover
Grayscale's Avatar
I'm more interested on the WiFi side of antenna boosting...but man those antennas are so expensive! Does anyone know if like a CB antenna would work? I know they have that wire wrapped in a coil around the main antenna so that might cause it to not pick up on the right frequencies, dunno...
Old 06-23-2004, 10:28 AM   #8
siberia37 is on a distinguished road
Not really true with GPS antenna's- some of the passive ones are DC shorts and can damage a receiver that expects an active GPS antenna. Best thing to do is find out what kind of antenna the unit uses currently and find one to match. My guess is it will be some kind of active 5v antenna- pretty standard.
siberia37 is offline   Reply With Quote
Old 06-23-2004, 04:55 PM   #9
dubwise
Thanks for the reply guys... I'm going to soldier a proper external antenna to the existing setup. I'll let everyone know the results, whether I blow it up or mod it proper.
Old 06-24-2004, 08:54 AM   #10
Pokey's Avatar
"Not really true with GPS antenna's- some of the passive ones are DC shorts and can damage a receiver that expects an active GPS antenna."
What??? enlight me....
Dual Lilliput's 70NP/C/T
Syntax SV266AD KT266A
AMD Athlon XP 2000
Viking 256MB DDR
D-Link Wireless 802.11B
Seagate 120GB
OrbitMicro 250W DC/DC converter
SII Wireless Audio Link
Digimoto OBD-II
Earthmate GPS
BU-303 USB GPS
D-Link Bluetooth
Old 06-24-2004, 10:58 AM   #11
Some older passive antenna act as DC shorts- I have read this in the manuals of a couple GPS units I put together from just the bare oem circuit boards (i.e. Oncore boards). Also all newer GPS's that take active antennas need a certain voltage active antenna- usually 5v but sometimes 3V,6V etc.. I found a page which explains this better than I can.
Old 07-04-2004, 06:36 PM   #12
awh4992's Avatar
awh4992 is on a distinguished road
for those of you trying to make an external antenna, heres one that's supposed to work good: http://www.arrl.org/tis/info/pdf/0210036.pdf i've made one, but haven't tried it cause i can't imagine this would have better gain than an active antenna anyways. this antenna doesn't short anything, so thats good too. also, whoever asked if ya can use a cb antenna or not, if it does work, that'd be pretty amazing as those antennas are cut to length and loaded for 30mhz or somewhere arond there, and the gps receives its signals on the 1.5 or somehting GHZ range. so for one the length of the cb antenna would be waaaaay too huge, and whatever loading coil they stick on there would probably attenuate the gps signal anyways. seein how these external active gps antennas r so cheap now (~$30 on ebay), ya could save urself a lotta time and other stuff
awh4992 is offline   Reply With Quote
external gps and aprs vehicle tracking swingwally GPS 12 10-23-2004 03:33 PM
Has anyone made external plastic boxes for GPS mouse/antenna? Sensor Fabrication 6 06-23-2004 11:13 AM
GPS Mouse? GPS Antenna? judoGTI General Hardware Discussion 5 03-20-2004 11:27 PM
Can you Paint external antenna? aforget GPS 3 12-27-2003 07:46 PM
USB 802.11b adapter with external antenna anyone? cyjad General Hardware Discussion 7 12-03-2003 10:07 AM
