Old 06-29-2004, 02:26 AM   #1
captain_jim1's Avatar
GPS Worked great - now doesn't.
So, I drove for 2 weeks across the country through all types of heat and rain with the GPS Mouse (ebay unit) running out the window and stuck onto my roof. It's been hot, it's been wet (waterproof unit) and it's been great .. until 2 days ago.
The unit will get a signal from satellites (I use Routis and it shows the 'degree' of lock it has -- i don't know how tobetter describe this), but it doesn't lock on any. I see that Routis is recieving information from the GPS unit (the long/lat fly by), but I never get 'green'... THEN!! every once in a while, 3 or 4 satellites will lock on, but have slow refresh rates.
I get the same results when I use the GPS software that came with the unit. Any ideas?
-Brad
83 mp320i
99 mp323i
_________
7" Lilliput w/Touch, 150 W Opus, 2.4ghz P4 533fsb, 512 DDR 333mhz, GPS, WiFi Inet, 40g Maxtor 7200rpm, Laptop DVD/CD-RW w/USB2.0 Bridge, WinXP Pro.
captain_jim1 is offline   Reply With Quote
Old 06-29-2004, 02:31 AM   #2
I had the same problems with mine.
I got mine on the inside of my car.
Is it a BU303? I don't know what I did, but I just changed USB-port and since that it has worked perfect for me.
storm is offline   Reply With Quote
Old 06-29-2004, 02:34 AM   #3
Yes, it's the BU303 -- I'll try a different USB-port... maybe it's a driver problem or something. Thanks for the reply....
-Brad
83 mp320i
99 mp323i
_________
Old 07-01-2004, 04:15 PM   #4
See me in my wet t-shirt.
stevieg's Avatar
I took my BU-303 through a car wash and it stopped working completely - for 24 hours! I thought it was broken (it had no light on at all, let alone blinking).
Think it's safe to say the BU-303 isn't water proof, maybe splash/rain proof to a certain degree. After that day, I haven't kept it on the roof since
Good way to check it's working to some degree is to use Hyperterm to connect to it it (at 4800 / 9600 baud) and see if you see the familar $GPRMC etc lines, if the lat/lon are 0000.00000 or similar the chip is working but can't get a lock.
Ford Focus MP3 : www.stevieg.org/carpc
Car PC Status: COMPLETE
stevieg is offline   Reply With Quote
Old 09-07-2004, 07:15 AM   #5
ShawJohn's Avatar
Try sealing it with a small bead of silcone sealant round the casing seam, cable outlet, and the LED hole... That should water proof it nicely!
HTH
John
ShawJohn is offline   Reply With Quote
garmin mapsource and usb gps mouse thecrow GPS 9 09-26-2006 03:24 PM
a new way of GPS brownpage GPS 8 08-24-2004 03:51 PM
Great European GPS software 4 touchscreen schakenda GPS 2 02-24-2004 04:46 AM
Cant get good GPS signal in car. Ricky327 GPS 8 01-29-2004 10:28 PM
Music and GPS Mikesz GPS 1 02-28-2003 03:26 AM
