The MP3car.com Store
Thread Tools Display Modes
Old 06-29-2004, 02:41 AM   #1
My Photos: (0)
Unhappy (Solved) epia m10k + lilliput + itps + morex 60w psu => gps blocker?
(PROBLEM SLOVED, see last post)
alright guys, I need some RF expert to help me out here.
I have a EPIA m10k mobo (laptop hd, dvd rom) + lilliput screen regulated by itps to a morex 60w psu. Here's what I discover:
My usb gps mouse will see the satellites under my front windshield, but it would never be able to get a lock. My lilliput is mounted on top of my dash. All the cables and wires are routed inside the dash to the computer under my glove box. I found out that if I turn the lilliput off, the gps was able to get a lock in seconds. So I thought the lcd was producing interference with the gps when on. However, if I connect Lilliput to a laptop instead of the mini-itx box, the gps locks the satellite too.
I figure that it gotta be the combination of m10k's onboard video device + lilliput resulted the problem. If I put the gps on the roof, I could get inconsistent lockings (I guess the metal roofing shields some interference). I have tested both the ebay gps mouse unit and delorme's earthmate unit, and they yield the same result.
I tried to tin foil the lilliput cable and the mini-itx box, but there was no difference. (however, I didn't ground the tin foil either. would that make any difference?)
Does anyone have similar experience or has any idea on how to fix this problem? You would be greatly appreciated!!!!!
NaFooEsi is offline   Reply With Quote
Sponsored Links
Old 06-29-2004, 03:03 AM   #2
TommieG's Avatar
Vehicle: 83 Porsche 930
My Photos: (0)
will it still lock with the liliput connected to the laptop AND leaving the mini-itx powered on?
Tom
VIA EPIA M9000/120 GB/Xenarc 700TSV/Opus 90W DC-DC
Haicom GPS/3Com 11g Wi-Fi/D-Link BT
WinXP/myHTPC/InfoMap Navigator Eu/PhoneControl w/T68i
Blaupunkt HU & speakers/Velocity active subs/Alpine amps
Progress: removed while waiting for nano-itx
TommieG is offline   Reply With Quote
Old 06-29-2004, 03:06 AM   #3
Vehicle: Alero
My Photos: (0)
I have the same setup (ebay mouse), I have had the same problem as you. But I don't have it anymore. Don't know what I did. But it may have something to do with that I now have the mouse connected to the extra USB-port. The one connected to the MB by a cable. Before I had it connected to the MB usb.
I have mine on the inside of the windshield.
storm is offline   Reply With Quote
Old 06-29-2004, 12:21 PM   #4
My Photos: (0)
Tom
Yes, it will lock. As long as the lilliput is not connected to the mini-itx, the gps locks.
Old 06-29-2004, 12:24 PM   #5
My Photos: (0)
storm do you connect it with a usb extension? or a usb hub? Is your mobo M10k?
Old 06-29-2004, 12:24 PM   #6
TommieG's Avatar
My Photos: (0)
did you try STORM's suggestion to try another USB port?
Old 06-29-2004, 01:13 PM   #7
My Photos: (0)
I used an extension cable => no difference.
I switched it to a different usb port on the mobo => no difference.
I have not tried an usb hub, but why would it make any difference in terms of interference?
Old 06-29-2004, 02:42 PM   #8
Raw Wave
Laidback's Avatar
Vehicle: Jeep GC
My Photos: (0)
Maybe a power issue?
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 06-29-2004, 03:28 PM   #9
My Photos: (0)
I know that it's not a power issue, because I had my friend in the car with a laptop connected to an independent gps to test the issue. When my lcd is on, he would lose lock on his gps. When the lcd is off, he would get the lock back.
It's very strange, and frustrating!!
The one scenario I have not test is to connect the mini-itx to a crt monitor to see if same thing happens...
Old 06-29-2004, 04:02 PM   #10
Vehicle: Audi 80 '89
My Photos: (0)
Have you tested it without touchpanel, just connecting vga to lilliput. It could be a conflict between gps and touchpanel.
Hope you can sort it out...
vvog is offline   Reply With Quote
Sponsored Links
Old 06-29-2004, 04:03 PM   #11
My Photos: (0)
I found out from a couple member that their m10k + lilliput works fine with the gps.....
I'm starting to wonder whether if it's the psu that I'm using. I have the ITPS with morex box, which comes with a 60w psu.
Would it be possible that the psu generates interferences when the lcd is turned on (draws more power?) but my lcd is powered by ignition tho....
Old 06-29-2004, 04:05 PM   #12
My Photos: (0)
Yes, I disconnected the usb touch screen cable, and it didn't make any difference.
If I disconnect the vga cable, the lcd loses signal and the gps locks fine.
If I connect the vga cable to a laptop instead of the mini-itx, the gps locks fine.
Anyone have the setup like mine?
m10k (512mb,40gb,dvd) + morex 60w psu + ITPS + lilliput
Ignition powers the lilliput and also triggers the ITPS.
Old 06-29-2004, 06:41 PM   #13
TommieG's Avatar
My Photos: (0)
I see from another thread that the liliput causes trouble to radios, too.
http://www.mp3car.com/vbulletin/show...threadid=28749
It seems that your concern about interference was right......
Hope that you eventually will sort it out.
Tom
Old 06-29-2004, 08:01 PM   #14
Rundell's Avatar
Vehicle: 98 Subaru Forester S Status: Error
My Photos: (0)
I have a similar problem with GPS. I could not get a lock no matter what. Right now I can tho. I have it pluged into the front of the morex case and used a USB extension and ran it to the back of my car, top corner of window. Now I can get a lock.
I am having the problem with the radio!! Heres a picture of my unshielded ribbon cable. I think that might be the cause but not sure.
Remember AllAdvantage From 7 years ago? IT IS BACK! Now under a new name Agloco
GET PAID TO SURF THE INTERNET
Rundell is offline   Reply With Quote
Old 06-29-2004, 08:07 PM   #15
My Photos: (0)
running the usb extension is not a true solution tho. I got tint on the back window, so that doesn't help the reception either...
Sponsored Links
vB code is On
Trackbacks are Off
FS: Lots of stuff (P4 EPIA, Lilliput, XA300) tbdombrosky Classified Archive 13 05-12-2004 12:19 PM
FS: Lilliput 7" VGA LCD in TM-701l casing (done by armen) & Earthmate GPS Shaar Classified Archive 14 04-18-2004 12:15 PM
self-build GPS Receiver => Avner GPS 15 03-16-2004 06:37 AM
suitable USB GPS for MediaCar 1.9 => Avner MediaCar 3 03-13-2004 07:03 AM
TV/FM Tuner W/ Epia M10k bklynkaos General Hardware Discussion 7 02-10-2004 11:00 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
