Old 06-30-2004, 04:54 PM   #1
pip
pip's Avatar
pip is on a distinguished road
Can I use Routis & Street Atlas together?
I have SA and an Earthmate GPS puck, and am sending off my old copy of SA for a competative upgrade to CoPilot 7. Can I run both software at the same time, both using the Earthmate puck? I expect I'll have to install the Earthmate 3rd party software drivers (http://www.delorme.com/support/gps/uemate005.asp) but will SA still work OK?
Anyone else doing this?
pip is offline   Reply With Quote
Old 06-30-2004, 05:10 PM   #2
Raw Wave
rando's Avatar
rando is on a distinguished road
First the disclaimer: If you send Sa in for a competative upgrade, you very likely are no longer legally entitled to posess a copy on you computer.
No, I haven't done this but it should work fine. The Earthmate USB can 'act' like a serial device with the appropriate Delorme drivers OR via a direct serial cable which you can buy or make yourself. In either case, it should work with any NMEA mapping package. If you want to both programs simultaneously, then you'll need to route the NMEA stream to two COM ports. Again, you can do this with a cable or with a COM port multiplexer / virtualizer software. Search the forums, it's been discussed several times.
Good luck.
2004 4runner
rando is offline   Reply With Quote
Old 06-30-2004, 05:24 PM   #3
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
I think I did it once. Run SA as normal usb receiver and routis thru one of the COM port that the Earthmate driver installed on your computer.
This setup sure will work.
- Install and run Xport (search the forum for it.)
- Run SA with virtual COM that Earthmate driver created.
- Configure Xport to have the "real" COM port on the one that Earthmate created and some virtual COM ports created by Xport.
- Run Routis with one of the virtual port that Xport created.
Note. Xport has problem with hibernation. Some members run GPSgate instead of Xport.
BTW I think the upgrade is for Copilot Laptop 7 not Routis.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 06-30-2004, 06:00 PM   #4
pip
pip's Avatar
Fair disclaimer, I phrased it badly. I have TWO copies of SA, 2004 and and older version (2002?). I'll be sending the old version in and keeping the new one.
Quite right, CoPilot not Routis.
Thanks, I'll send off & give it a try.
Old 06-30-2004, 08:33 PM   #5
lucho's Avatar
lucho is on a distinguished road
GPSGate
Look for this software called gpsgate. I run copilot and routis together, works fine. It reads data on com 3, or whatever you use then you create virtual comports and set each program to use these. Works good and it is cheap.
Luis
Epia M1000, two 80 GB Hard Drives, Lilliput 7" TS, 512 MB DDR, 300 Watt Power Inverter with Relay, Wireless USB Adapter. Routis 2004, Copilot 2003, Rayming TN-200 USB GPS in a 1999 Isuzu Rodeo
lucho is offline   Reply With Quote
I replaced the male voice of my Delorme Street Atlas with a british female voice... dmbrown73 GPS 21 03-07-2006 11:43 PM
Street Atlas 2003 No Map Displayed? Urinemachine Software & Software Development 1 06-17-2004 12:12 AM
Using Street Atlas and/or Leadtek TV2000 hanzacra Software & Software Development 0 04-22-2004 10:51 AM
Street Atlas isn't all that great... any ideas? swellfellaT GPS 42 03-30-2004 06:18 PM
Navman Reciever w/ Delorme Street Atlas 2003? csvt GPS 9 06-11-2003 08:33 PM
