Old 07-06-2004, 11:33 PM   #1
asci01's Avatar
GPS with simultaneous music
This is probably and dumb question but I was wondering if you can listen music while using your GPS at the same time with your carputer.
Does it depend on the software you're using? If so which one can do it (e.g. Frodoplayer, Mediacar, Media Engine, etc.)
asci01 is offline   Reply With Quote
Old 07-06-2004, 11:53 PM   #2
MoFo's Avatar
I use FrodoPlayer and routis 2004 all the time. works great.
I can even hear the voice navigation telling me when to turn while the music plays.
MoFo is offline   Reply With Quote
Old 07-07-2004, 12:57 AM   #3
Jesus Freak
antimatter's Avatar
works fine for me... my m10000 hangs for a second sometimes when loading copilot live
antimatter is offline   Reply With Quote
Old 07-07-2004, 01:57 AM   #4
computer = Multi-tasking
You don't have to use any special programs. You can just use winamp to play music on the background while using mappoint or any gps software.
Mediacar and any of these carputer softwares also allow you to play music while performing other embeded tasks.
NaFooEsi is offline   Reply With Quote
Old 07-07-2004, 07:41 AM   #5
StationRocket's Avatar
I use iGuidance (same as routis) and Media Engine and they work together fine, music and vioce dirrections. You even get a nice overlay of the music controls in the corner while using the GSP software. You'll want to use Frodo's LMF.exe to resolve a little bug with the combo. There is also a nice little utility that someone here on the boards wrote to autoclick the nag screen about driving safe.
StationRocket is offline   Reply With Quote
Old 07-07-2004, 07:59 AM   #6
lucho's Avatar
New Utility
Frodo made a new one that launches and clicks the warning screen in one executable. It is not dependent on resolution or font size. RoutisLauncher
Luis
Epia M1000, two 80 GB Hard Drives, Lilliput 7" TS, 512 MB DDR, 300 Watt Power Inverter with Relay, Wireless USB Adapter. Routis 2004, Copilot 2003, Rayming TN-200 USB GPS in a 1999 Isuzu Rodeo
lucho is offline   Reply With Quote
Old 07-07-2004, 08:18 AM   #7
carpcnoobie's Avatar
I have Routis and Media Car and no problems using them both at the same time. Occasionally it hangs for a sec if it's accessing a large # of POIs.
But it plays and navigates at the same time, no problem. Routis also lowers the music volume slightly so voice prompts can be heard. Pretty slick.
I'm just trying to figure out how I can make Routis play over a speaker when listening to the regular radio.
Progress Meter:
[|||||!||||'] 95% complete
It's in... it's finally installed!!!! But never finished!
"It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
carpcnoobie is offline   Reply With Quote
Old 07-09-2004, 10:53 PM   #8
asci01's Avatar
Thank you all for your response. This makes my project one step closer
Old 07-10-2004, 01:16 AM   #9
I'm sorry, and you are....?
frodobaggins's Avatar
Luis
Unless you use Media Engine, then you need to use LMF and Routis launcher in combination.
FrodoPlayer.com
TeaBaggins.com
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
Old 08-30-2004, 07:37 PM   #10
wysocki's Avatar
I want to use RoutisLauncher in MediaCar and I'm having a real brain fart with this configuration. I got lmf going in my apps to run XMpcr but the instructions there were pretty specific for apps. As I understand it, I'll have MC running lmf, which runs routislauncher which runs routis.
Where do I put the folder/instance of lmf if using with routislauncher (which in turn will point to routis.exe). Whew! Can anyone simplify this with a step by step?
wysocki is offline   Reply With Quote
Old 09-02-2004, 05:47 PM   #11
AutoTouch Creator
Gremlin's Avatar
Autotouch will let you do both, and it'll pause the music to tell you the voice navigation...
-Gremlin
Gremlin is offline   Reply With Quote
Old 09-02-2004, 05:51 PM   #12
jpelzer's Avatar
Just a heads-up for those of you on the cheap, the old VIA M5000 doesn't have enough power to do MP3 and run GPS at the same time. It was really painful. The mp3's stuttered every time the screen refreshed.
MII-10000, now that works great!
jpelzer is offline   Reply With Quote
Old 09-02-2004, 05:56 PM   #13
swingpoha's Avatar
Will routis launcher work with iGuidance?
My obligatory progress meter.
[|||||||||||||||||||-] = 95%
Basic Install done and all bugs fixed.
Need: GPS, OBD
swingpoha is offline   Reply With Quote
Old 09-02-2004, 09:29 PM   #14
Yes.
System:
Epia M1000 w/512MB PC2100, Xenarc 700TS, ATI 7500 PCI, OPUS 150 PSU, 2.5 40GB 5400 HDD, 802.11g PCI, Slim Slot DVDR,
Gyration RF Kybrd, OBDII adpt. + sftwr, XP pro, iGuidance/Royaltek GPS NAV, XMPCR, Kenwd KAC-8401 4 chnl amp, 10" pwd sub
UncleGeek is offline   Reply With Quote
Old 09-02-2004, 10:23 PM   #15
What kind of application is Autotouch?
2004 Toyota Corolla S
EPIA V8000A, 3.25GB & 60GB laptop drives, Lilliput 7" touchscreen, 200W and ITPS
Currently running WinXP, MediaEngine, & iGuidance
BriCubz is offline   Reply With Quote
CoPilot the only way to go for GPS! lbk GPS 17 02-19-2007 04:21 PM
How do you get the music to mute when GPS is giving directions? blak3r GPS 0 04-29-2004 01:46 AM
GPS voice guidance and music... sounder GPS 1 09-15-2003 05:39 AM
DISH TV music storage project... claylong General Hardware Discussion 2 04-16-2003 09:08 PM
Music and GPS Michael Szilagyi GPS 1 02-28-2003 02:26 AM
