Old 08-18-2004, 02:36 PM   #211
xtra is on a distinguished road
what you can do is to create differnent maps and make a backup of the MAP folder. cut and paste when you decide which map you going to use.
xtra is offline   Reply With Quote
Old 08-18-2004, 02:51 PM   #212
robr is on a distinguished road
Thanks for the idea, but that's a ridiculous bandaind for a poor installer. I believe I have them all installed now (the installer started barfing about being unable to find several files toward the end but as far as I can tell, all the map data is there. I even ran the installer again and it listed all maps as being installed). I left the data copying over to my laptop this morning when I left for work. I love debugging released commercial applications... sigh.
robr is offline   Reply With Quote
Old 10-31-2004, 05:46 PM   #213
Stank Cheese
n8scstm's Avatar
n8scstm is on a distinguished road
In order to efficiently manage the maps first generate map data for your first location – then rename c:\iNav iGuidance\ directory. Load another set – and you’ll see that iGuidance recreated the folder with a new set of maps. You can now freely rename the directories back and forth to switch your datasets. You can also copy these folders to your PocketPC overwriting existing files to switch your available map data without the need to re-generate map information every time.
n8scstm is offline   Reply With Quote
Old 11-03-2004, 08:40 PM   #214
trdcpu's Avatar
trdcpu is on a distinguished road
iguidance 2 + frodoplayer = scrumtrilescent
trdcpu is offline   Reply With Quote
Old 11-03-2004, 09:18 PM   #215
d_sellers1's Avatar
d_sellers1 is on a distinguished road
Embeded would be nice. Automatically go to mini-mode and not allow more than one instance of iGuidance would make it perfect.
Derek
Progress [||-------]
View my Worklog to see some of my progress.
Downgraded Progress - Starting with another car... 09/13/06
d_sellers1 is offline   Reply With Quote
Old 11-03-2004, 09:37 PM   #216
I'm sorry, and you are....?
frodobaggins's Avatar
frodobaggins will become famous soon enoughfrodobaggins will become famous soon enough
Derek
Haven't checked out Take 3 yet I see.
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
Old 11-03-2004, 10:14 PM   #217
d_sellers1's Avatar
Thumbs up
Haven't made it to that section of the forum. Guess that will be my next stop.
Derek
Old 04-20-2005, 02:14 AM   #218
Has trouble reading.
sanbas's Avatar
sanbas is on a distinguished road
for all the iguidance 2.1 users in here...I am using that software with a Rikaline 6010 USB receiver purchased from USB.
This is my first GPS experinence and to say the least i was blown away how accurately it worked (have only used it locally so far). I have been reading around about all this sirf vs nema and higher baud rates.
I guidance doesnt have any settings for sirf or nema...is it safe to assume that its only compatiable with nema, b/c my Rikaline 6010 is sirf or nema capabale.
Works good as it is but i just dont want to be missing out on anything.
P.S. FYI the rikaline 6010 has a very strong magnetic base so it can be attached to the outside, i connect to 7-9 satellites when outside maximum is 12 which it has gotten before i think. AND 4-6 satellites when its inside the car next to the rear brake lights.
sanbas is offline   Reply With Quote
Launching iGuidance under Media Engine StationRocket GPS 4 11-29-2004 01:56 PM
USB 2.0 3.5" hard drive adapter - WOW! Yuriy General Hardware Discussion 22 11-04-2004 08:42 AM
Switch between Frodo player and GPS (IGuidance)? Nanozic FrodoPlayer 2 07-12-2004 02:58 AM
2 questions about 2.0. jgme ME Archive 3 09-04-2003 04:42 PM
2.0 review hijinks21 ME Archive 20 07-16-2003 08:02 AM
