Old 07-20-2004, 08:12 PM   #16
jpelzer's Avatar
Quote: Originally Posted by jcdillin
I doubt it, it's more likely the ground plane effect, thats why xm or other sat radios have to be mounted at least 6 inches from your window to get a big enough ground plane to pick up the weak signal from space.
Ground plane effect is actually what I'm talking about. It is not an amplification, but actually a removal of interference (multipath interference, specifically). The signal level that a GPS displays is actually a signal-to-noise ratio, and by adding the ground plane, this ratio is improved.
That being said, your car is an excellent ground plane, even if you don't have your GPS on a piece of metal... There are two types of multipath that affect GPS: Multipath from the ground and multipath from above (buildings). There aren't antenna designs that help with the latter issue, but a ground plane helps with ground-reflections. Your car is a ground plane, even without the foil.
So I guess what I'm saying is that a ground plane can improve signal in handheld units (hiking for example) but is much less likely to cause noticable results with a car, since the car already is acting as a ground plane.
jpelzer is offline   Reply With Quote
Old 07-21-2004, 03:56 PM   #17
pip
pip's Avatar
Well, my car is mostly plastic (C5 Corvette), so I suspect a ground plane may help improve my lock then?
pip is offline   Reply With Quote
Old 07-21-2004, 03:59 PM   #18
Jesus Freak
antimatter's Avatar
Who else has done this.... does it work... Post!
antimatter is offline   Reply With Quote
Old 09-13-2004, 09:19 AM   #19
It's not really that small...No, seriously.
judoGTI's Avatar
*bump*
'02 GTI
[Routis '04] [Opus 90W] [160GB Maxtor HD]
[Lilliput 7" TS] [VIA M10000] [XMPCR]
[512MB RAM] [Custom housing]
[Deluo GPS Mouse] [E-MU 0404 Soundcard]
Progress Meter: [==============|] 99.9%
judoGTI is offline   Reply With Quote
Old 09-13-2004, 09:43 AM   #20
jpelzer's Avatar
It works.
Some time after this discussion, I moved my gps to the skylight in the back of my car, so it was suspended in midair with no metal below it. I'd removed the magnet (magnets make me nervous with computers), and so it wasn't geting ANY signal lock.
I now have a 3" diameter piece of aluminum stuck below the receiver, and the lock is perfect. Aluminum foil would work just as well, just doesn't look as slick!
Bush: Proof that humans really did evolve from apes.
Old 09-20-2004, 01:07 PM   #21
faichiu's Avatar
I can't believe it. The refigirator magnet works for me!!! The GPS get lock quicker than before.
Quote: Originally Posted by daman10958
I was experimenting the other day on what I should do to mount My Earthmate because it was taking a while to get lock while in my car and I stumbled upon a solution that is both simple and cheap and really if you think about the physics makes some sense.
All I did is put a $2.00 refigirator magnet on the bottom of the GPS. it covered the bottom at about the size of the base and when I put it in the same spot that was getting (mediocre -> poor) signal reception it suddenly got a solid lock.
after I thought about it it is the same reason that they work better on the roof of your car. the reciver is designed to be on top of a ferrous ( including Iron) metal. Therefor the signals from above can come directly into the reciever or get bounced off of the base metal only to get caught on the trip back up.
Maybee this will just work for me but I thought I'd share my little sucess.
98 Honda civic
In-Dash LCD Monitor K-301
cappuccino EZ3
PIII-1.2GHZ
256MB PC133
40GB HD
Holux GR 213 Sirf Star III GPS
IguidanceV2
CNX-P1900 power supply
Sound Blaster Live USB
faichiu is offline   Reply With Quote
Old 09-20-2004, 03:11 PM   #22
ppgt94's Avatar
I just took my BU-303 out from the front (on top of the dashboard, under windsheild). I moved it too the back and mounted to the metal trunk lid (BU-303 has built in magnet). I did get more satellites. I then moved it inside the car under the rear windsheild on the rear deck and got about just as good of a signal. I hate putting it in the rear of the car because I feel as if tracking is behind a few feet. I rather have it be ahead than behind.
ppgt94 is offline   Reply With Quote
Old 09-21-2004, 11:43 AM   #23
hmmm... can I mount it upsidedown? Maybe I'll mount it under my bonnet.
Course how would I be able to receive a good reception if it's under the bonnet???
Maybe mounting it near the vents??? Then it's not upsidedown...
The more I type, the more this post doesn't make sense.
nl4jy is offline   Reply With Quote
Old 09-21-2004, 01:23 PM   #24
mutilator's Avatar
my mates got gps under his pollen vent infront of window wipers, works fine.
tom.
Car: 2005 Mini Cooper Convertable
Status: startin from scratch. [|--------]
Hardware:
EPIA 1000M
Dlink USB radio
7" In dash touchscreen
Harmain GPS unit
RF remote
ODB2
....IBUS comin soon
Running: media engine
mutilator is offline   Reply With Quote
Old 09-23-2004, 11:03 PM   #25
carpcnoobie's Avatar
Quote: Originally Posted by jpelzer
It works.
Do you have any pics of this? I'd like to see it. I'm still working on where to put my GPS. If I can improve my lock situation, that would help out a lot.
Progress Meter:
[|||||!||||'] 95% complete
It's in... it's finally installed!!!! But never finished!
"It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
carpcnoobie is offline   Reply With Quote
Old 09-24-2004, 05:40 AM   #26
blicky_1's Avatar
Smile
Hi all,
I used to have my GPS mounted on top of the rear shelf and had lock problems with 3-4 sats at best (ebay GPS)
I now have it under the rear shelf on the metal (facing up) and get between 8-10 sats with instant lock!!
With my Merc you can get to the metal shelf by taking out the first aid kit and mounting it behind and the replacing the kit, no one would ever know its there!
Works for me!!
Regards
blicky_1
blicky_1 is offline   Reply With Quote
Old 09-24-2004, 05:59 AM   #27
Rub One Out
Motoko's Avatar
So does it have a view of the sky?
CarPC status: iPod, 3,456,217 songs so **** you
Motoko is offline   Reply With Quote
Old 09-24-2004, 09:09 AM   #28
blicky_1's Avatar
no it is under the shelf but the shelf has a clear view of the sky.
Old 09-24-2004, 09:20 AM   #29
MySQL Error
jcdillin's Avatar
Quote: Originally Posted by hd54321
XM uses a combination of ground repeaters and satellites(sp?). Line of sight is more important than a ground plane.
-HD
Interesting. I dont have XM I have sirius, I dont know if sirius uses ground repeaters, I would think that would keep it from loosing signal under bridges but I could be wrong. I figured it was all sat based.
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 09-28-2004, 03:38 PM   #30
Sirius uses very few ground repeaters compared to XM. I will have to try the magenet thing when i get my truck back
FAmonmouth is offline   Reply With Quote
GPS mouse won't lock Jemmi GPS 18 06-22-2004 12:44 PM
gps takes forever to lock! aznblueeboi GPS 1 04-23-2004 12:52 AM
Grrr! why wont my gps lock? [H]Bugster GPS 13 02-15-2004 09:36 PM
Cheap GPS Receiver M pro GPS 9 08-22-2003 06:47 AM
GPS and VFDs - cheap smashr2k General Hardware Discussion 6 07-08-2002 10:54 AM
