Quote: Originally Posted by c4shm0ney
I'm posting a picture of my setup below. The GPS can not get a lock sitting where it is at. The enclosure is made of aluminum and has been painted. The reciever is looking up through the rear window. Is the aluminum case a groundplane or not? Would mounting a heavy magenent on the underside of the car about 2 inches under the enclosure make a groundplane?
Any advice is appreciated.
The aluminum case should work fine as a ground plane. If you move the whole thing outside your window, does it lock on? If no, you probably have bigger issues. If yes, I'd take a look at any coatings that may be on your rear window, such as anti-UV.
I doubt adding a magnet would help. The case should make a much better ground plane than any small magnet would. You may try varying the distance between aluminum and antenna, that may have some effect (closer generally better)
