Old 08-10-2004, 02:20 AM   #1
Mik
Mik's Avatar
Exclamation BU-303 not working correctly
I have a problem with my BU-303 GPS mouse.
I have installed it on my pc and laptop, and have the same problem with both.
After I have installed the driver and plug in the mouse. I have a problem getting my pc/laptop to recognise the com port assigned to the mouse. Using the application that came wit the mouse, I click the ‘scan com port’ button and sometimes it will find the port and others it wont. I have tried connecting using two application, Autoroute and InfoMap. Also tried using HyperTerminal.
When it does work, it does so for a bout 2 or 3 minuets and the problem persists until I reboot or mess about with the com port settings.
Is it the unit or my PC and Laptop, they are both running Win2k.
Thanks for any help,
Mik
Mik is offline   Reply With Quote
Advertisement Sponsored links
Old 08-10-2004, 04:51 AM   #2
4u2n's Avatar
Mik
I have one to
The SPECIFICATIONS
if it not have bin uset in more than 2 days
the Cold Start can take 5-15 min
ref taken form www.g-sat.dk
Plan for project = 100%
Part the project. = 100%
Built...................= 99%
Finish.................= 99%
Install ...............= 99% -50%
Ditail at 4u2n.dk
Here
4u2n is offline   Reply With Quote
Old 08-10-2004, 10:39 AM   #3
Mik
Mik's Avatar
Using it daily, have left conected to the pc woth the dongle out of the window. The LED will start to flash after about 60secs, but i still have the same problem with it. Even sat out side with the laptop and have the same problem.
Old 08-10-2004, 11:02 AM   #4
I have this exact same issue when i connect my mobile phone to my computer if I have power hungry things attached to the same USB host. might be work unplugging anything else u have, (i assume your not using an unpowered hub)
Paul
Paul_ is offline   Reply With Quote
Old 08-10-2004, 11:05 AM   #5
Works fine for me.
My Microsoft Mappoint saw it easily as a com port, I did have to install all the Windows Updates on one of the computers because I hadn't done it in a while (Windows 2000).
Try that, if not...you've got a defective one or try another USB slot so it automatically adds more com ports.
yuprules is offline   Reply With Quote
Old 08-10-2004, 11:10 AM   #6
SAScooby's Avatar
I think its a com port conflict, what other applications use your com ports ?
check this out, uninstall all of them, install the gps first and then the other applications.
Things to look out for:
Microsoft Activesync
Cellphone software (number updates, phone books etc)
Bluetooth applications
and you get the idea, its probably somehting that looks for the com port every few minutes to do a sync / update that is messing you around.
Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
FS = MTSVO motorised in dash screen pm me for details
SAScooby is offline   Reply With Quote
Old 08-10-2004, 11:26 AM   #7
Mik
Mik's Avatar
Ok think you might have solved it, i have both the laptop and pc set up the same. will try a few things a let you know.
Thanks for the help, these fourms are priceless
Old 08-19-2004, 11:50 PM   #8
Mik I am having the exact same problem with mine. Did you find anything more out on this ??????
johnnyutah36 is offline   Reply With Quote
Old 08-21-2004, 05:39 AM   #9
Mik
Mik's Avatar
No, johnnyutah36
I am moving houses at the moment so havent had a lot of time to mess with anything like this, just keeping an eye on the fourm when i get an email.
will let you know if i do find anything. should imagine it will be a loong time off yet.
Old 08-21-2004, 05:28 PM   #10
In my case, the com port is not recognized by the software from the cd, but my gps software works ok more or less.
Epia M10000
PW80
40GB 3,5"
Touchscreen 7" Lilliput
Still "housing" it.
windalo is offline   Reply With Quote
Bug Reports frodobaggins FrodoPlayer 168 10-16-2004 01:25 AM
Put computer into standby/hibernate = firewire cdrom driver stops working psyclobe General Hardware Discussion 0 04-28-2004 12:38 AM
motorized screen stopped working :( corsamel LCD/Display 0 11-26-2002 11:52 AM
Everything working correctly? bgoodman Off Topic 16 09-15-2002 01:13 AM
Someone please help 10 hrs wasted working on 4 x 20 Character LCD Martin S. Shepherd LCD/Display 1 05-31-2001 11:25 AM
