Old 08-10-2004, 09:35 AM   #1
Need the BU-303 driver
Iīve just received the gps usb bu-303 dconnex of Ebay, but the minicd is empty, windows does not recognize any driver from cd, so I canīt get it work.
Could someone tell me how to get the driver or send them to me to caslop7@supercable.es ?
A question about this unit, is it always on? the light is on while the pc has power. How do you do it to disconnect it?
windalo is offline   Reply With Quote
Old 08-10-2004, 11:38 AM   #2
4u2n's Avatar
I have take alle from the mini disk and pak them i a file
you can download it on this link
www.4u2n.dk/USB_BU_303.rar
Plan for project = 100%
Part the project. = 100%
Built...................= 99%
Finish.................= 99%
Install ...............= 99% -50%
Ditail at 4u2n.dk
Here
4u2n is offline   Reply With Quote
Old 08-10-2004, 11:58 AM   #3
You unplug it.
To turn it off:
You unplug it from the USB port of your computer
yuprules is offline   Reply With Quote
Old 08-10-2004, 06:49 PM   #4
Thanks to both, 4u2n sorry the disturbance, the problem was my drive, it does not read small cdīs, I installed another one and it can read small cdīs. It was telling me it was empty but it wasnīt.
Lot of effort to run it and I did a test, but itīs not the thing I though. I placed it below the front window and nothing, nothing and more of nothing. When I took the unit outside, perfect, it takes 4 satellites, but inside the car, nothing. And I have a Seat, the window is normal, and I have seen the same car with the same unit in the same place and working. Whatīs going wrong?
By the way (for Europeans), Mapsonic (by Michelin) is pretty, but a sh..... fuc...ng sh..t it tooks me by the worst way to come back home, sometimes says "turn to the right" when it was showing the opposite, and the correct was the opposite, sometimes just in time... but for getting it not so expensive jejeje.
Are your units working inside well?
Old 08-11-2004, 11:17 AM   #5
Smile Unit refuses to work inside
GPS signals are very low, even trees block it. Try it in an open area not moving, the first time it loads it will take 2-15 minutes to lock on. after that, it will take under a minute to lock on since it "knows" where part of the earth is.
My GPS never works inside, and doesn't even work under trees. It isn't the unit, that's with almost all units.
Old 08-11-2004, 12:43 PM   #6
I have the BU-330 and never need to wait for the lock when its on my front dash in the corner., it seems instataneously. It has gone out for a second or two here and there. However, the first, it may take bit of time to lock,
mykolJay
99 Accord coupe
http://www.geocities.com/accordpc
My Project Thread on mp3car.com
mykolJay is offline   Reply With Quote
Old 08-11-2004, 08:08 PM   #7
Well, testing my unit this night, it was not working in the front, impossible. It works in the rear window, but in the top, outside, it tooks the same satellites but with more power.
Between buildings with narrow street it does got lost, and itīs difficult to find itself again, may be it was the position of the unit, but I do not understand, my from window is not atermic, itīs normal one (my car is normal), only it has a coloured smoke in the top for the sun, but I placed the unit the lower as possible.
anyway at least I have GPS
Epia M10000
PW80
40GB 3,5"
Touchscreen 7" Lilliput
Still "housing" it.
Widescreen driver need a host yunusyu LCD/Display 2 05-28-2004 09:13 PM
deluo gps driver problems plz help!! BobbyD GPS 2 04-29-2004 06:18 PM
XP - Lilliput- wrong display driver???? Custommx3 LCD/Display 6 01-14-2004 02:18 PM
FV24 and Xenarc wide screen driver How to cproaudio LCD/Display 3 03-15-2003 01:16 PM
USB Sound Card with ASIO driver and volume control tbdombrosky General Hardware Discussion 0 02-04-2003 12:00 AM
