Old 08-17-2004, 11:01 PM   #1
Rand McNally GPS Unit Not Working Right
I have a Rand McNally serial GPS unit connected to a Keyspan USB adapter running Pocke Nav
It is behaving very wierd. It appears to be behind actual tracking of roads when I approach, and the speed is significantly delayed. What is really odd is sometimes the map will look like I am flying over off road areas, or it will say I am on a completely different road while driving.
What could be causing this, and what settings should I double check?
MSUC5Vette is offline   Reply With Quote
Old 09-11-2004, 01:39 PM   #2
LESLIEx317537's Avatar
Which Keyspan serial to USB adapter are you using?
SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
GPSing - Digital Speedo
Relocating headunit and extending faceplate
Button app to Alt-Tab between two programs
LESLIEx317537 is offline   Reply With Quote
How to make the Garmin GPS 35 Work with Copilot 2003 fluffy2097 GPS 16 09-05-2007 05:19 PM
Destinator SDK + Destinator GPS Module miguelito GPS 3 07-21-2004 02:48 PM
Window Tint's effect on GPS signal MoFo GPS 3 07-19-2004 06:08 PM
Serial GPS unit, does it use pin 8? LittleDragon GPS 10 04-15-2004 06:51 PM
GPS Interferes with DSCustoms Touchscreen! Help! gork LCD/Display 4 09-04-2003 10:20 AM
