08-18-2004, 10:15 AM
#1
Help with destinator 2 SDK
Hi guys!
I'm having some problem getting Destinator 2 to work!
I have installed the SDK. Then I took maps from a installation disk for Destinator 2 Pocket PC.
I put the maps in the Destinator folder in different folders.
When I try starting Destinator SDK I get:
"Your current map Sweden02Q101 is erased or damaged. Choose other map or reload current"
I've tryied to uninstall Destinator SDK and do it all over again but it won't work!
Could anyone help me figure thís one out?
Thanks in advance, Kalle
Progress Meter [||||||||||]
I Have: Epia M10000, 40gb 2,5HDD, 512mb Ram, 2,5" Slimline CDRW/DVD Combo, Inside a Morex 3688. USB GPS Mouse.
I Need: USB Fm Radio, USB 2.0 Hubb, Wiring
08-18-2004, 10:20 AM
#2
Raw Wave
Quote: Originally Posted by Kalle.se
Hi guys!
Did you unzip the files inside the map folders?
08-18-2004, 10:36 AM
#3
Yes, they are all unzipped
08-18-2004, 05:43 PM
#4
I now know that it's only the Sweden maps that is giving me problems. All others work. But since I live in sweden It's the swedish maps I wan't.
All other maps exceept the swedish ones end with (_A.file extension)
If I rename the swedish files to look like the others it says my map is corrupted. If I don't it says it's erased or something.
Any clues?
08-18-2004, 09:48 PM
#5
hmm im curious why it says Sweden02Q101
To me that means its missing part 1 of the sweeden map but then again i dont know just looks funny.
It would make sense as if 1 of the .DAT files is missing it wont work as all the dat files need to be there for the full map to show up.
There wasnt any other sweden downloads for destinator???
08-18-2004, 10:06 PM
#6
The swedish map is divided in three parts, therefore three zipped files. I can't Unzip them all to the same directory because they are called the same. I haven't tryid unzipping them to different directories and renaming them _A
I'm trying this now!
Didn't work =(
08-18-2004, 10:18 PM
#7
Thats just because the folder it was in was called Sweden02Q101.
So it's not any version code or so.
08-18-2004, 10:59 PM
#8
I don't know then i'll download the sweden maps tonight and see if i can figure it out
How big is it again? might take a while
1 thing to check is in the zipfile does it say the directory it export out as?
08-19-2004, 08:21 AM
#9
Well the problem only seems to be with the D_F_N_S maps. (Denmark, Finland, Norway, Sweden)
All other countries install perfectly. This is ****ing me of big time!
Has anyone installed these maps on Navigator 2 SDK and got it to work?
Please tell me how then =)
/Kalle
08-19-2004, 12:32 PM
#10
Raw Wave
They work for me - but the Sweden folders on my cd are called S1, S2 etc.
S1:
Eastern Sweden
Version 2002.Q1.1273c NC
I can put them up on the DC++ hub if you want.
08-19-2004, 05:12 PM
#11
I would love that!
I won't be home for a week or so. Took a litle vacation =)
I'll PM you when I get home!
Thank you very much =)))
08-19-2004, 08:25 PM
#12
I'm glad to see this worked out for you kalle
Laidback: Did u use the sdk in VB to make that program?
I'm trying to create my own frontend like that but it wont work
do you have the source??
08-19-2004, 11:26 PM
#13
Raw Wave
I used the SDK to put it in Meedio. This code should get you running, I can't remember who posted it....
08-20-2004, 10:25 AM
#14
Thanks laidback i'v got it but i am having problems
The window doesnt seem to fully maxamize id like to be able to get rid of the top bar so it looks intergrated likes yours does but show the bottom menu of destinator.
do you know how i can do that?
08-20-2004, 11:34 AM
#15
Raw Wave
Declare these...
Code:
Private Declare Function SetWindowLong Lib "user32" Alias "SetWindowLongA" (ByVal hwnd As Long, ByVal nIndex As Long, ByVal dwNewLong As Long) As Long
Private Declare Function GetWindowLong Lib "user32" Alias "GetWindowLongA" (ByVal hwnd As Long, ByVal nIndex As Long) As Long
Const GWL_STYLE = (-16)
Dim lStyle As Long
Const MY_WS_DOCK = WS_CAPTION Or WS_THICKFRAME Or WS_SYSMENU
then use this to get rid of the titlebar & frame etc..
Code:
lStyle = GetWindowLong(theHwnd, GWL_STYLE)
lStyle = lStyle And (Not MY_WS_DOCK)
SetWindowLong theHwnd, GWL_STYLE, lStyle
and this function gives you the window handle..
Code:
Private Sub Destevent2_OnCreateDestinatorWindow(ByVal hwnd As Long)
theHwnd = hwnd
End Sub
| Thread Tools |
| Display Modes |
Linear Mode
