Old 09-01-2004, 10:42 AM   #1
Can I paint my earthmate?
Would it hurt my earthmate if I took a can of flat spray paint and painted it from that stickout yellow to maybe black or grey?
Daps is offline   Reply With Quote
Old 09-01-2004, 11:02 AM   #2
EBFoxbat's Avatar
Makes sure there is no metal in the paint. If should be fine.
'04 Canyon 4x4 pickup
[---PC on hold----working on external fiberglass "tool" box---]
EBFoxbat is offline   Reply With Quote
Old 09-01-2004, 11:04 AM   #3
I would recomend if you remove the cover first, you don't want any thing inside the housing.
kingtut is offline   Reply With Quote
Old 09-01-2004, 11:14 AM   #4
Thanks for the quick response. I'll take the top off and give it a once over.
Old 09-01-2004, 11:48 AM   #5
Change's Avatar
Try to track down some vinyl dye, it's a spray that permanently dyes plastics. You'll probably have to dye it white first, and then whatever color you want. Or black. It has the advantage of not scratching off like regular paint (which just adheres to the surface) will.
Change is offline   Reply With Quote
Old 09-01-2004, 12:03 PM   #6
About how much does this cost?
I mean if it's expensive. I'll just use the $1 spray paint and touch it up every so often..Call me cheap
Old 09-01-2004, 01:00 PM   #7
Change's Avatar
Sticking with the $1 paint you've got would be best then, this stuff runs about $7/can.
Old 09-01-2004, 01:02 PM   #8
pip
pip's Avatar
You could dip it in plastidip & make it waterproof too
pip is offline   Reply With Quote
Old 09-01-2004, 02:22 PM   #9
$7 a can ouch that is steep. Would have to find a ton of other stuff to dye to make it worth it...
Old 09-01-2004, 04:39 PM   #10
vinyl die is the best, i have a can of mat black. used it to paint a cd-rom drive and the case of a pc. still loads left.
Best thing to do when spraypainting is light coat, lots of times. not one big coat of paint.
pioneer is offline   Reply With Quote
Old 09-01-2004, 10:09 PM   #11
Registered User
Mitokondria's Avatar
I bought a spray can of vinyl dye for only $4 dollars at the auto parts store. I had one use for it, but the stuff is so cool I started finding excuses to paint things black.
- 3+ years & still no carputer!
- Done collecting parts
- Currently planning setup
Mitokondria is offline   Reply With Quote
USB Earthmate - patch for gpsd support dignome GPS 4 04-05-2005 10:44 AM
Possible help for USB Earthmate and Routis/IGuidance rgardjr GPS 21 06-30-2004 01:17 AM
Paint type LittleDragon Fabrication 5 04-24-2004 05:35 PM
Car Paint Repair Question Max018 Off Topic 4 03-12-2004 12:03 PM
Earthmate only locks when GPS Software is running nodeel GPS 5 01-04-2004 09:43 PM
