The MP3car.com Store
Thread Tools Display Modes
Old 09-01-2004, 08:45 PM   #1
owenjh's Avatar
My Photos: (0)
to all with handheld GPS mounts
Hey, I made this unit because I wanted a better way then having to plug the cable into my GPS reciever everytime I got in the car and I didn't want to leave it in the car all the time. It is a radio shack suction Cell Phone Holder that was on sale for $9.99 I drilled a hole for the back with a dremel, cut the back of the casing so that the pfranc connector could fit thru, made a cable using the pfrac connector and then assembeled everything together. I had problems with my first cable, it came loose and the computer kept losing signal, I just redid the cable, and it seems to work alot better then before. Any way here are the pictures, if you would like more pictures or information let me know. I was going to make a how-to but its pretty self explanatory. btw the GPS reciever is an oldschool garmin GPS 12 and it uses the 5 pin garmin connector.
- edit Wow sorry about the bad pictures, they came from an intel cam I won, will submit more pictures as there is a lack of them
CarComputer Status: New Car & Broken (Motherboard Fried)
Owen JH | My Linux Blog | The Tech Fellows
owenjh is offline   Reply With Quote
Sponsored Links
Old 09-02-2004, 04:40 PM   #2
owenjh's Avatar
My Photos: (0)
Any coments/questions on this? I want to hear feedback!
Old 09-02-2004, 10:12 PM   #3
MySQL Error
jcdillin's CarPC Specs
jcdillin's Avatar
Vehicle: 2002 Dodge Ram 1500 Quad Cab
My Photos: (3)
I like it, mine is setup almost the same way except I used a GPS 48 which has a BNC plug for the antenna so I could reroute the antenna to a better place
jcdillin is offline   Reply With Quote
Old 09-04-2004, 12:04 PM   #4
owenjh's Avatar
My Photos: (0)
Did you have any problems with GPS timing out?? Im having problems at the moment, I think its because the pins arn't long enough to go thru the extra plastic. it works untill you close it, which is a pain because you can't operate it with it open... I wouldn't mind an external antenna for mine... maybe they have a mod for it :-P
Old 09-04-2004, 12:16 PM   #5
MySQL Error
jcdillin's Avatar
My Photos: (3)
no none, but I did change the connecter to a dsub I didnt want to spend the money on the combo data/power cable. I pulled my gps 12 apart thinking the same thing. I added a antenna on a foot long high grade coax and it made it worse, I dont think the reception circuts are very good in it. because I used the same cable and antenna for my 48 and it improved greatly. But I think after all this I am going to the gps76 which my friend has and it locks in like 5 secs warm
Old 09-04-2004, 09:58 PM   #6
owenjh's Avatar
My Photos: (0)
I don't have a problem with my 12 really, it just takes a minute to lock. The problem im having is my cable not making a good connection. Guess I will ripp it apart again and see if I can fix it. Im making my data/power cable, but I have to get the data part working first :-P you can buy the plugs from pfranc.com I got 3 plugs for $15 shipped. Its a great service.
Sponsored Links
vB code is On
Trackbacks are Off
garmin mapsource and usb gps mouse thecrow GPS 9 09-26-2006 02:24 PM
FS: GlobalSat bluetooth GPS receiver and Street Atlas 2004 handheld chiefsalami Classified Archive 11 09-02-2004 12:40 AM
a new way of GPS brownpage GPS 8 08-24-2004 02:51 PM
Window Tint's effect on GPS signal MoFo GPS 3 07-19-2004 05:08 PM
Using a handheld GPS with a carputer? commodore_dude GPS 1 05-19-2004 06:49 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
