Old 09-04-2004, 01:35 AM   #1
captain_jim1's Avatar
GS Reciever, WinXP SP2, and Hibernation
Wasn't Service Pack 2 supposed to fix the issue with the GPS recievers coming out of Hibernation properly? I installed SP2 for this reason alone and have the same issues I have where Routis loses the GPS connection when I resume from hibernation.
Any help?
-Brad
83 mp320i
99 mp323i
_________
7" Lilliput w/Touch, 150 W Opus, 2.4ghz P4 533fsb, 512 DDR 333mhz, GPS, WiFi Inet, 40g Maxtor 7200rpm, Laptop DVD/CD-RW w/USB2.0 Bridge, WinXP Pro.
captain_jim1 is offline   Reply With Quote
Old 09-13-2004, 08:51 AM   #2
It's not really that small...No, seriously.
judoGTI's Avatar
I still have this problem too with SP2... ?
'02 GTI
[Routis '04] [Opus 90W] [160GB Maxtor HD]
[Lilliput 7" TS] [VIA M10000] [XMPCR]
[512MB RAM] [Custom housing]
[Deluo GPS Mouse] [E-MU 0404 Soundcard]
Progress Meter: [==============|] 99.9%
judoGTI is offline   Reply With Quote
Old 09-13-2004, 01:28 PM   #3
zPilott's Avatar
are you using a usb hub? external power or bus power?
I was having a problem with my usb touchscreen until I got a usb2.0 bus powered hub (it has external power but I dont use it) and SP2.
|V1 Virtual Display|
Hard work often pays off over time, laziness always pays off right now.
zPilott is offline   Reply With Quote
Old 09-14-2004, 11:22 AM   #4
judoGTI's Avatar
I have a powered USB 2.0 hub, my touch screen and wi-fi resume fine, its just the GPS receiver.
'02 GTI
Old 09-14-2004, 12:46 PM   #5
owenjh's Avatar
Whats a GS reciever? Anyway, not sure if this will help but try to disable power saving features in the device manager for all of your USB devices. This might help might not.
CarComputer Status: New Car & Broken (Motherboard Fried)
Owen JH | My Linux Blog | The Tech Fellows
owenjh is offline   Reply With Quote
Old 09-14-2004, 06:49 PM   #6
I am using a bus powered USB GPS "Mouse" .. I'll check my power-saving settings when I go back to the car... this still sucks though
-Brad
83 mp320i
99 mp323i
_________
Old 09-14-2004, 11:05 PM   #7
leemik's Avatar
This was a promising idea and i tried it but since my GPS mouse is detected as a USB to serial COM port in the device manager, there is are no power saving options.
--mike
leemik is offline   Reply With Quote
Old 09-14-2004, 11:59 PM   #8
owenjh's Avatar
--mike
What about for the USB root hub... try that one, its worth a try, there should be power options for it.
Old 09-16-2004, 10:14 PM   #9
leemik's Avatar
tried it .. still doesn't work
Old 09-17-2004, 06:29 PM   #10
I'm using the GPSGate beta to solve this problem. Previous versions of the software wouldn't allow the computer to suspend while using it with a usb gps, but the beta version solves this problem. It's not free software, but it's cheap, and it fixed all of my gps issues.
http://franson.biz/gpsgate/support.a...platform=winxp
You need to submit your email address for instructions on how to get the beta.
This has solved these problems for me.
-USB Earthmate wouldn't work in routis or iGuidence
-GPS would not work after coming out of suspend or hibernate
-Sometimes GPS software would flake out and crash coming out of suspend
-Fixes would take a long time. (I get a fix almost instantly now coming out of suspend)
-Could only use 1 app at a time with the gps
Basically the software sits between the gps port (or emulated port) and spits out data to any number of virtual ports. It also does some voodoo black magic to keep the data stream flowing correctly to the application. Also, it will continue trying to re-open the port if there is an error of some sort.
Hope this helps.
Woobie is offline   Reply With Quote
Old 09-19-2004, 04:12 PM   #11
My Village Called
0l33l's Avatar
Try the latest version of RoutisVoice. It detects resume and it restarts Routis automatically
PowerVoice v1 | NaviVoice Source
GammaControl v2.4
SKINbedder v3
1995 Lexus SC300 <-- Weekend Car
1997 Mazda Miata <-- Daily Driver
0l33l is offline   Reply With Quote
