09-07-2004, 07:02 AM
#2
umm if u can read chinese or what ever its written in
It aint no family car.
SEE MK2 At : -
http://www.mp3car.com/vbulletin/showthread.php?t=22810
09-07-2004, 08:04 AM
#3
Rub One Out
Its Japanese, but i have no idea whats going on lol
CarPC status: iPod, 3,456,217 songs so **** you
09-07-2004, 08:25 AM
#4
Raw Wave
Why is it better than normal GPS that can be bought apart from it being cheap?
The writing look very chinese to me. Would be interesting to know whats going on
09-07-2004, 08:55 AM
#5
Here is your answer: BLUE TOOTH = NO WIRES!
That is wicked, I wonder if there are any of those little gadgets avaliable in the USA.
If so, that serial - blue tooth thing could be used as a modem cable too?
Found a few links:
Bluetooth Serial Adapter:
http://www.socketcom.com/product/CS0400-479.asp price is $160
Samething but cheaper:
http://www.securemart.com/cgi-bin/fu...6.html?pcode=4
Does any one know, if its possible to use the following
PC > USB Blue Tooth \/ wireless link thru bluetooth \/ USB Blue Tooth > USB > Serial Adapter > GPS
09-07-2004, 09:16 AM
#6
Raw Wave
Found a few links:
I think he may have been asking why is it better than a normal BLUETOOTH GPS from the shop...
09-07-2004, 11:44 AM
#7
Guess so.
Found another bt serial adapter, this ones cheapter tho:
http://store.aircable.net/aise4.html $49
its powered thru pin 9 dc 4-10v or by an optional power supply which is $3
This looks quite cool, I might get one or two for wireless OBD & GPS im wondering if it could free up my com-ports.
09-07-2004, 11:54 AM
#8
Raw Wave
But don't they connect to your comports?
09-07-2004, 11:55 AM
#9
Raw Wave
Location: Spagcave, in da UK Today's phrase: J'aime Alizee
It's in Chinese
09-07-2004, 12:13 PM
#10
Yes, It's simplified Chinese. That Bluetooth GPS seems to be rechargable.
09-07-2004, 12:18 PM
#11
Why not just get THIS and a USB BT Dongle. That is what I did. It has a 8 hour battery life as well.
09-07-2004, 12:25 PM
#12
Thats what im wondering. By the looks of things you can get a USB bluetooth adapter and a Aircable serial module for $49 and pair the dongle with the module and have a wireless serial > bt > USB link.
I think this would be quite good if it works with any BT dongle, because the total wireless link would be $49 for serial adapter and $30 for a USB BT dongle.
I have e-mailed them asking them if it will work with any bt dongle. fingers crossed hopefully it will.
09-08-2004, 01:43 AM
#13
I've checked that page
IT IS NOT A pure BLUETOOH SERIAL
it will be searched as another BT device but can works fine as a serial
09-08-2004, 01:49 AM
#14
OEM BLUE TOOTH GPS MODEL - III SPECIFICATION
General Specification:
Outside Dimensions: 80mm (L) x 35mm (W) x 10mm (H)
Weight: 65grams
GPS Engine (module): SEIKO EPSON, Japan
Battery Operation Time: 8 hours (per charge, continuously)
Display: 5 color LED (power on / charge / Blue Tooth / Linkage / Low Battery)
Power Switch: One Soft Touch, Touch On then Touch OFF
Connectors: One MINI USB Socket for Battery Charge only
Operating Temperature: -40 to +85 degree C
Storage Temperature: -55 to +105 degree C
Relative Humidity: 20% - 90% (no condensing)
Feature of Product (model II only): can be buddled to specific single host device
(In this mode, this BT-GPS can be used with ONE buddled host device ONLY,
And can not be found by other Blue-Tooth host's serarch)
Other Features: The thinnest BT-GPS would wide update
GPS Performance Specification:
Power Consumption: lower than 100mW (30mA@3.3V without Active Antenna)
Data output Standard: NMEA 0183 Version 3.0, Default serial at 9600/N/8/1
Max Data Update Rate: 1Hz
Frequency: L1 Band (1575.42MHz) C/A code, 8 channel, continuous tracking receive
Sensitivity: -150dBm
Horizontal Accuracy: < 6 meters (50%), < 9 meters (90%)
Altitude Accuracy: < 11 meters (50%), < 18 meters (90%)
Acquisition
Reacquisition: < 2 seconds (90%)
Hot Start: < 14 seconds (50%), < 18 seconds (90%)
Warm Start: < 38 seconds (50%), < 45 seconds (90%)
Cold Start: < 90 seconds (50%), < 170 seconds (90%)
Dynamics: 4g
Operational Limits: Altitude < 18000m or Velocity < 515m/s (1854Km/h)
Transparency Blue Tooth UART Performance Specification:
Compliant with Blue Tooth specification v1.1
+4dBm power class 2 support
SMD multi-layer chip antenna inside
Default work range 10 meters
Standard UART interface, TX/RX/RTS/CTS at rate 9600bps -1.5Mbps (Default at 9600/N/8/1)
Power saving mode support
Authtoration and security support
Built-in qualified RF+BB-chip and link manager protocols and supports these protocols:
LM, LC, L2cap, SDP, RFCOMM, and BlueTooth serial port profile
Photo of OEM BT-GPS model-II for reference only
09-08-2004, 01:53 AM
#15
pic of II
| Thread Tools |
| Display Modes |
Linear Mode
