Old 09-11-2004, 12:45 PM   #1
carpcnoobie's Avatar
carpcnoobie is on a distinguished road
GPS Mouse dead??
I have a BU-303 (ebay mouse) and it seems to be having problems. I bought it a few months ago and it's been working great, but a few days ago I was getting GPS info, then it died. No warning, nothing. Now, when I start up cold, it will work for about 2-3 mins then it will stop. The light will light up bright at first then is dimly lit. It was writing sentences then stopped suddenly. I tried on both my car pc and my laptop and had the same results. This was mounted on the trunk for a few days and did go thru a rainstorm, although nothing major. Anybody know what's wrong?
Thanks.
Progress Meter:
[|||||!||||'] 95% complete
It's in... it's finally installed!!!! But never finished!
"It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
carpcnoobie is offline   Reply With Quote
Old 09-11-2004, 12:47 PM   #2
jeremyp111 is on a distinguished road
If it got wet then that's most likely the source of your problem. Take it apart if you can and put a hair dryer to it. See if that works. It may come back to life. Good luck.
jeremyp111 is offline   Reply With Quote
Old 09-13-2004, 10:07 AM   #3
I opened it up and found what appeared to be rust or something like that, so it is possible water found it's way inside. It was a touch wet in there, and I dried it out, but I'm still having the same problem.
Does anybody know what the warranty information is for these things? Or do I just have to bite the bullet?
Progress Meter:
Old 09-18-2004, 10:58 AM   #4
**update**
It lives again!!! I opened it up two times and tried drying it out as best as I could. Well, I thought it was hopeless and I was going to be ordering a new one. Well, last night I had my carPC out for some repairs and new program installs. I decided to plug my GPS mouse in again... the darn thing works!! I'm still a little weary, but as best as I can tell, it's working fine. It showed on Routis where I am and everything. Stranger things have happened.
Progress Meter:
Old 09-18-2004, 01:46 PM   #5
Glad to hear it's back working for you. I would get some CorrosionX or Boeshield T-9 and spray it down before the corrosion gets worse. Spray it and let it dry before putting it back together. Then you should be fine.
Old 09-18-2004, 01:48 PM   #6
Raw Wave
kickercivic1's Avatar
kickercivic1 is on a distinguished road
may i am ask where it was mounted?? i am trying to find a place to mount mine lol.
kickercivic1 is offline   Reply With Quote
Old 09-21-2004, 10:43 AM   #7
Jeremy- Thanks for the suggestion, I'll go out and get some, but I think I'm going to try to find a place that is dry. Or perhaps use some sort of water proofing like I've read in a few threads here.
KickerCivic- The only time the mouse got wet was when I washed it and forgot it was on there. The mouse was sitting on my deck lid which is almost perfectly horizontal, so water may have had time to set and pool up. That was the best place to get a lock.
Progress Meter:
garmin mapsource and usb gps mouse thecrow GPS 9 09-26-2006 03:24 PM
Wtb: Gps Software And Gps Mouse!!!! HitmanZ Classified Archive 2 08-03-2004 10:56 PM
GPS Mouse (BU303) Notes captain_jim1 GPS 6 07-18-2004 01:01 PM
New GPS Mouse and Routis carpcnoobie GPS 5 06-04-2004 07:17 AM
GPS Mouse? GPS Antenna? judoGTI General Hardware Discussion 5 03-20-2004 11:27 PM
