Old 09-14-2004, 03:35 PM   #1
It's not really that small...No, seriously.
judoGTI's Avatar
judoGTI is on a distinguished road
New fix regarding jumping mouse with Deluo Routis GPS
I emailed them and asked for a more perm. fix since every resume/reboot my mouse goes crazy and this is what they provided me with. I wont be able to test it until later, but hopefully it helps.
"Dear Our Most Valued Stud-Muffin,
The problem you describe happens sometimes when Windows recognizes a GPS data
stream as a Microsoft BallPoint device that has just been connected to the
computer.
Microsoft has started to build a solution for problems like the one you are
experiencing. Please find the Knowledge base article at:
http://support.microsoft.com/default...b;en-us;819036
We have tested it on several PCs and laptops and it worked OK on all cases. This
is a beta tool and may contain bugs, but its an easy to use command line
tool.
Hope this helps solving your problem.
Kind regards,
The Deluo Team"
'02 GTI
[Routis '04] [Opus 90W] [160GB Maxtor HD]
[Lilliput 7" TS] [VIA M10000] [XMPCR]
[512MB RAM] [Custom housing]
[Deluo GPS Mouse] [E-MU 0404 Soundcard]
Progress Meter: [==============|] 99.9%
judoGTI is offline   Reply With Quote
Old 09-14-2004, 10:00 PM   #2
judoGTI's Avatar
has anyone gotten this to work? I tried to install the .msi file but it didnt seem to let me run the command prompt syntax's?????
'02 GTI
Old 09-14-2004, 10:07 PM   #3
MySQL Error
jcdillin's Avatar
jcdillin is on a distinguished road
thats interesting i'll have to give it a try on my laptop
jcdillin is offline   Reply With Quote
Old 09-15-2004, 05:04 PM   #4
judoGTI's Avatar
Bump anyone else have any luck??
'02 GTI
Old 09-15-2004, 05:37 PM   #5
Bbrian
I got the same results you did...installed the file but command line doesn't work. Even if it did work windows wants you to reboot after enabling the com port which defeats the purpose of this app doesn't it? I mean you need to disable com port of the gps mouse during boot up and turn it on after boot up or when you want to use GPS but windows wants you to reboot after re-enabling it.
EDIT: FYI ... the command lines will work if you copy the exe into the SYSTEM32 folder. You can also run it from the directory that it was installed.... just change to the directory to where it was installed and run the command lines.
Shuttle xPC w/ Athlon 2400+
512MB ddr266
GeForce4 128MB agp video
250GB WD SE
USB2.0 DVD/CD-RW slim drive
7" Xenarc TSV touchscreen
PAC Audio AUX input module
Opus 150W PS
iGuidance usb GPS
RF keyboard/mouse
Mobile Media Center
Bbrian is offline   Reply With Quote
Deluo GPS kit, w/ Routis 2004 NovaKane Classified Archive 1 08-30-2004 04:35 PM
Some warnings about Deluo Routis 2004, MapPoint 2004 & XPort dumpper GPS 13 07-15-2004 01:07 AM
deluo gps jumpy mouse on bootup all the time fondoo GPS 2 06-18-2004 09:54 AM
New GPS Mouse and Routis carpcnoobie GPS 5 06-04-2004 07:17 AM
Deluo Routis pictures.. ahh!!! SWEET GPS!! fondoo GPS 16 05-13-2004 03:34 PM
