Old 09-16-2004, 08:58 AM   #1
electron is on a distinguished road
Triggering events based on GPS location
I am in the process of building my car pc, and I would like to include GPS navigation using one of the better software packages out there. However, I also would like to run a certain exe or macro whenever I am within a short distance from my house, while getting close.
The only way to do this would be by looking at the GPS data and see where I am and see if I am leaving or approaching the house. Is this something some GPS software can do already? If not, would I be forced to chose between GPS nav and that functionality (I will write my own software) or can most GPS units be shared between the several software packages running? Thanks!
electron is offline   Reply With Quote
Old 09-16-2004, 09:31 AM   #2
EBFoxbat's Avatar
EBFoxbat is on a distinguished road
I would imagine, if you can program, which I can not, that you could take the data stream from the GPS and have it trigger events based on location etc. I don't think it would be all that hard.
I think the issue is that if you are using the GPS data for your own little app, then u can't use it for traditional GPS apps
'04 Canyon 4x4 pickup
[---PC on hold----working on external fiberglass "tool" box---]
EBFoxbat is offline   Reply With Quote
Old 09-16-2004, 10:00 AM   #3
Raw Wave
Confused's Avatar
Confused is on a distinguished road
I'm sure it'll be pretty simple to get something like this into AIMEE
Garry
Co-Developer of A.I.M.E.E
www.aimee.cc
Confused is offline   Reply With Quote
Old 09-16-2004, 10:17 AM   #4
Raw Wave
ShawJohn's Avatar
ShawJohn is on a distinguished road
Have a look at EvetS, google 'EvetS' and 'Speedcam'. IIRC This is a VB based program that triggers a sequence of Wav files when approaching a GATSO camera's GPS location... Maybe you could use this in some way, add your house as the only GPS location in a database and have it run a batch program or something...
The guy who wrote this app is known as Goto10 on this forum... He maybe able to help you.
John
ShawJohn is offline   Reply With Quote
Old 09-16-2004, 12:24 PM   #5
wi77iam's Avatar
wi77iam
A port splitter like GPSGate can create multiple virtual ports that can each feed a NMEA data stream to separate apps. I've already had MapPoint, Routis and my own little GPS app running at the same time.
wi77iam is offline   Reply With Quote
Old 09-16-2004, 12:57 PM   #6
wow, very nice find! This is exactly what I am looking for.
a new way of GPS brownpage GPS 8 08-24-2004 03:51 PM
Window Tint's effect on GPS signal MoFo GPS 3 07-19-2004 06:08 PM
GPS Based Security System chewiee GPS 1 04-29-2004 01:59 PM
Photo based GPS navigation ? felix99 GPS 7 03-02-2004 02:28 PM
GPS location ? cvi MediaCar 2 11-21-2003 07:23 PM
