Old 09-22-2004, 10:24 AM   #1
Deactivated
Diewlay Lowmo's Avatar
Diewlay Lowmo is on a distinguished road
Garmin : GPS35 vs GPS18
Is the technical difference substantial enough to justify the price difference (more than double) between the two:
GPS18: http://www.garmin.com/products/gps18oem/spec.html
GPS35: http://www.garmin.com/products/gps35/spec.html
Do they both not update 1x per second?
Diewlay Lowmo is offline   Reply With Quote
Old 09-22-2004, 10:28 AM   #2
akw
akw is on a distinguished road
Garmin 18 is not NMEA compatible
If you're referring to the Garmin 18 USB, then you should know that it only produces Garmin binary data, not NMEA data. According to Garmin, there is only one other company that has written software to interface with the Garmin USB interface (other than Garmin). The other company is Northport Systems and their product is called FUGAWI Moving Map.
Hope that helps.
akw is offline   Reply With Quote
Old 09-22-2004, 03:14 PM   #3
Deactivated
I'm reffering to both models in PC (serial + cigarrette jack) format.
Old 09-23-2004, 01:58 AM   #4
bill_best is on a distinguished road
Thumbs up Yes.. 18pc will output NMEA
Here is a FAQ for the different GPS 18 models.
http://www.gpscentral.ca/products/garmin/18.htm
You had me worried for a while that the 18 serial version wouldn't work.. phew!
I saw in another message that you have a shop in Toronto near the DVP and 401. What shop is it? Do you sell OPUS power supplies?
Thanks!
Bill.
bill_best is offline   Reply With Quote
Old 09-23-2004, 03:10 AM   #5
Deactivated
Compatability was never an issue.
What makes the GPS35 sell for double that of a GPS18 when they both update @1x/sec?
Old 09-23-2004, 03:18 AM   #6
Deactivated
C'mon GPS35 owners speak up and reprahzent...
Bill, It seems as though opus does not want to have anything to do with Canada.
Old 10-06-2004, 01:42 PM   #7
Response from Garmin...
Here is the response I got from Garmin concerning the differences between the 35 and 18pc..
Dear Bill,
It's really a matter of cost of materials. The GPS 35 PC design, being an
older design, uses more expensive parts. The GPS 18 PC is in most respects
a better design for significantly less money. The only differences worth
noting (other than WAAS compatibility as you noted) are that the GPS 18 PC's
cigarette lighter plug contains a voltage regulator that steps down from 12
V automotive to 5 Vdc and that the GPS 18 PC's serial output voltage swing
is from 0 to 5 V, rather than the -6 to +6 V used by the GPS 35 PC. If you
remove the cigarette lighter plug from a GPS 18 PC, its voltage supply
requirements change to 5 Vdc, rather than 12 V automotive.
If you are just plugging into a cigarette lighter socket for power and
plugging the DB-9 serial connector to your laptop's com port, then the GPS
18 PC is a functional replacement for the GPS 35 PC and the price is roughly
cut in half.
Regards,
Brad Wiseman
Straight from the horse's mouth!
Bill.
Old 10-08-2004, 01:52 PM   #8
Deactivated
Thanks for the confirmation Bill Best.
You're the best.
Btw..an opus may be available for sale soon... pm me for details...
Old 10-13-2004, 09:13 PM   #9
Deactivated
Backorder in stock....!
Gonna buy it tommorrow.....
Garmin 18 problems, please help studmonk3y GPS 6 08-31-2006 04:41 PM
Garmin GPS35 for sale e36mp3 Classified Archive 3 05-11-2003 05:31 PM
Will the Garmin GPS35 usb work with copilot 2003? e36mp3 GPS 3 04-09-2003 11:48 AM
Garmin 35 PC USB VS. Deluo USB Receiver SLAYER6669 GPS 0 10-03-2002 01:33 AM
For those considering the Garmin GPS35... jshrieve General MP3Car Discussion 19 05-29-2002 04:29 AM
